Engine keeps flooding out
  • b*saint
    • 3794
    I would plug it in and read fuel trim.
    Ma che cazzo state dicendo? :|
    • r3d e30
      • Dec 2010
      • 55
      How do I read the fuel trim? Where can I get the scanner to do so?
      Because I said so, thats why.
      • b*saint
        • 3794
        O wait the cars on here are so ass old you can't do that anymore. On my car, I plug in a Snapon scanner with the BMW adapter and I can read anything.
        • r3d e30
          • Dec 2010
          • 55
          as far as I know this is an obd 1. So I have no idea how to read the fuel trim on it.
          • b*saint
            • 3794
            Im sure there are obd1 scanners that can read active data except they are either really expensive or hard to find. I had to get adapters for the vantage to read my 94 hondur.
              I don't believe a Motronic 1.3 DME is sophisticated enough to be able to report fuel trim.
              • accident
                • 7303
                definitely not OBD1
                Moral of this story?
                • r3d e30
                  • Dec 2010
                  • 55
                  I dont know. The more I look at this engine the more I think it is a bastardized product of stupidity. The previous owner didn't know how to read a service manual, I think. The cold air intake on it looks like he took dryer duct tubing and jerry rigged it. How can I tell if its really running rich. I have fuel in the oil, and it smells very rich. But when I run pressure test and fuel flow test it all checks out fine, so my guess is its just not gettting the right amount of air. Would a bad AFM prevent the right amount air to get into the engine?
                  • NC325iC
                    • Mar 2004
                    • 6565
                    Motronic 1.3 fault code 1232 indicates a bad throttle position idle switch
                    • r3d e30
                      • Dec 2010
                      • 55
                      Where can find a list of codes for future use? Also is that just the throttle position switch?
                      • b*saint
                        • 3794
                        You can use your meter to find out. It should read a value of resistance while open then just drop to whatever your leads ohm out to when the throttle is closed. At least thats how it is on a toyota I worked on.
                          One clue that the engine is running rich is to take a look at the spark plugs. If they are black, either the engine is running rich or it is burning oil. The definitive check on the A/F ratio is to put the car on a dyno with a wideband sensor monitoring the exhaust.
                          The TPS contains two switches. One is the idle switch that closes with the throttle is closed and tells the DME to control idle speed with the ICV. The other is the WOT switch.
                          • NC325iC
                            • Mar 2004
                            • 6565
                            Let Me Google That For You (LMGTFY): for all those people who find it more convenient to bother you with their question rather than search it for themselves.
                            • r3d e30
                              • Dec 2010
                              • 55
                              If I dont clear the codes out, will the car use the last value it had when the code was set in the DME? In other words, do I have to manually clear the codes or will it automaticly clear it out after the repair? BTW I think I will end up having to replace the DME
                              • Adrian_Visser
                                • Jun 2006
                                • 2823
                                Okay attempt number two at a reply. Fucking firefox.
                                Disconnect the battery for ~15 min. the codes are erased.
                                I have had this problem and have also solved it by replacing the DME (ecu)
                                To definitively check, disconnect the c191 connector under the intake manifold (round plug for injector harness) Then using a multimeter set to ohms test for ground on pins 6 and 7 on the body side of the connector with the key in the run position, engine off.
                                If your DME is functioning properly there will be no continuity to ground i.e. very high or infinite resistance. If you have very low resistance like say 10 ohms it's safe to say that the injector drivers in the DME are burnt out.
                                '89 Alpine S52 with goodies
