Help needed will start and run with the key in the start position only
    Does the engine run fast enough to disengage the starter? If so I'd say that some circuit that should be hot in Run & Start is only hot is Start. Unless and aftermarket alarm has been installed that would mean a bad ignition switch.
    • ejnight
      • Apr 2007
      • 3488
      It had a old UNGO alarm. I pulled it all out. still does it. Picking up an ignition switch Wednesday.
      http://raceskids.com/
      • ejnight
        • Apr 2007
        • 3488
        New ignition switch did not work.
        • mr.vang
          • 4371
          is your car an autotragic?
          • b*saint
            • 3794
            a schematic would be tits.
            Ma che cazzo state dicendo? :|
            • ejnight
              • Apr 2007
              • 3488
              Yes it is.
              • ejnight
                • Apr 2007
                • 3488
                Any one?
                • DaveSmed
                  • Apr 2007
                  • 1406
                  Grab a test light. Attach it between the green wire on your ignition coil, and a chassis ground.
                  Proper operation is on with ignition on and in the start position.
                  -Dave
                  2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                  Need some help figuring out the ETM?
                  • SeasSoShining
                    • Dec 2010
                    • 26
                    Very interested in this thread... What relays did you change?
                    As far as power distribution goes, it seems that most of the wiring is shared between "run" and "start" positions on your ignition switch. Meaning: it should be easy to isolate what wiring/compenent specific to the "run" position is failing if this is an electrical problem. I'm ignorant when it comes to automotive ignition systems, so my musings may seem rediculous to someone with more experience... What about the starter hold-in coil?
                    ...These schematics have been around, but I figured I would post them to help in the discussion. Not sure what model year you're dealing with. If it's your '91, the schematic here isn't showing an automatic specific schematic... The older publications do.
                    E30 Wiring Diagrams: http://www.armchair.mb.ca/~dave/BMW/e30/
                    • ejnight
                      • Apr 2007
                      • 3488
                      the three main ones on the fender well.
                      • SeasSoShining
                        • Dec 2010
                        • 26
                        Which three relays exactly?
                        From what I've gathered from the schematic, when you go from the "start" position to the "run" position to you are changing the source of power for the starter motor...
                        "Start:" Battery > Battery Junction Block > Starter Motor > Ground.
                        "Run:" Battery > Battery Junction Block > Ignition Switch > K5 > Starter Motor > Ground.
                        Someone else should chime in.
                          The only electrical difference between Run & Start is that in Start the ignition switch supplies power to the starter solenoid.
                          • DaveSmed
                            • Apr 2007
                            • 1406
                            Those relays only control accessories. There is only one wire going from the ignition switch to the DME. That one wire also happens to connect to the ignition coil. Thus the suggestion of the following test earlier in the thread.
                            -Dave
                            • ejnight
                              • Apr 2007
                              • 3488
                              I broke down and towed it to Mike O'Hara Service 5020 NE Cully Blvd, Portland, OR. If these guys can't fix it, I will part the POS. I will let you know what happens.
                              • Pennyw1se
                                • Jul 2009
                                • 121
                                Dibs on front and rear bumpers! Just kidding. Good luck. Make sure you post the solution. Has me curious.
