Help needed will start and run with the key in the start position only
I have added staring fuel and it still will not run unless the key is in the start position. I have changed the relays and the ECU nothing helps. Dead and need help.
I think I'm confused now. Will the engine fire then die when you spritz the intake with starting fluid? Or does it not fire at all?
it fires and runs on its own as long as you are holding the key in the start position. Hell on the starter so I don't do it long, as soon as you let go it dies. even with starting fuel sprayed in it.
So the car will start and run as long as you hold the key in the start position only, but when you let go and it springs back to the run position it dies?
so the car will start and run as long as you hold the key in the start position only, but when you let go and it springs back to the run position it dies?
