e30 352i 1989 coupe, where to put steering Fluid
  • TKDBoi249
    • 14
    Hey guys im a noob at this. I looked in the car manual and didn't see where to put steering fluid. I have steering fluid in the garage but i don't wanna put it in the wrong place. And is there a certain kind of fluid i should use and also i have a manual. And if im not mistaken i heard there is a difference between ATF and power steering fluid. If you can explain that to me that would be great also.
  • IminDiegoTriick
    • Oct 2009
    • 1564
    Automatic transmission fluid and power steering fluid are the same thing. Hydraulic fluid.
    So using and buying these two items are interchangable..
    as for the location there is a power steering resoivoir by the fuse box.. assuming your car is an m20 motor.. cuz you put e30 352i in the title. lol.
    But yee right by the fuse box theres a cap you twist off..
    Fast life fuck slow..Low life for life
    Let the mix flow..Let the night flow
    I'm so gone ✗ ♥ O
    • TKDBoi249
      • 14
      thanks man, ohh and about the m20 motor thing im not sure haha. But ill trust you since you know what you are talking about haha. Thanks again man
        • 37829
        No, they are not! Do not use power steering fluid, use standard MD3 ATF.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • Holland
          • Nov 2008
          • 7178
          This thread scares me. If your car is a 325, then it should have an M20.
          Originally posted by DEV0 E30
          • TKDBoi249
            • 14
            wait so dont use power steering fluid? whats the difference
            • IminDiegoTriick
              • Oct 2009
              • 1564
              I gotta dissagree.. power steering fluid & ATF are hydraulic fluid period. But I also agree that using MD3 ATF is the best.
              I am using Dexron ATF..
              I'm so gone ✗ ♥ O
              • TKDBoi249
                • 14
                lol ok ill use ATF then...
                  • 34839
                  ATF is a different weight of fluid, and has detergents and friction modifiers that PS fluid does not.
                  The system is designed to use ATF, so that's what you should use..
                    While power steering fluid and ATF are both hydraulic fluids, their composition is very different. Using the wrong fluid in a system will usually cause seal damage. In this case the power steering system requires ATF.
                    • a3ternus
                      • 643
                      Its a 352! Cant you read?
                      N.
                      Originally Posted by aaron_silva
                      It is always frustrating having a harsh ride when
                      you arent in the right mind set.
                      • TKDBoi249
                        • 14
                        thank you guys!!!
