Last week I was driving, and all of a sudden a loud screeching noise & my dash lights came on (battery, brake, etc). Pulled over, and had the car towed to my local E30 shop.
Upon investigation, it turned out the waterpump pulley had seized. It was replaced w/ a new one, and the car drove fine....until I realized there was no HEAT at all.
Heat worked fine prior to this incident, so today my shop replaced the thermostat, bled the system for almost 2hrs (tons of air pockets in the system), and replaced a couple sensors by the thermostat (not exactly sure which ones).
None of the above solved the issue. Any ideas what the problem could be before I start replacing every part under the hood?
TIA.
TIA.
