no HEAT, after waterpump seized....help!
    #31
    Originally posted by audiquattrot
    so a friend and i were ready to replace my heater valve today. we went to drain the radiator first (to avoid coolant from gushing out into the cabin) and no coolant came out, so i couldn't even replace the valve today. The radiator looks to be plugged w/ gunk at the very bottom. we stuck a metal hanger to see if we could free stuff up, but there was no trace of coolant. Car doesn't overheat, so I suppose there is coolant running thru it. I know there is hot coolant going to the firewall since that hose leading into the heater core is HOT. Is there a way I can flush this radiator enough to drain the coolant (so I can replace this valve?).....or is there another explanation you know of as to why there isn't anything draining at all? The coolant tank is full at all times.
    You can drain the radiator by removing the bottom hose. The chances of successfully cleaning that radiator are pretty slim. it would be a lot better to just replace it.
    • audiquattrot
      • May 2008
      • 3836
      #32
      Find this.
      GM P/N 12346500
      Do what the can says. Read twice, work once.
      P.S. - The acid neutralizer is in the bottom of the can.
      thanks for the advice guys!
      www.instagram.com/snwmble
      #snwmble
      Current:
      '05 BMW M3 - Silver Grey/Imola Red
      '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
      '15 Mini Countryman - Blazing Red/Carbon Black
      Past:
      '01 Audi Allroad - Light Silver/Platinum Saber Black
      '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
      '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
      '90 BMW 325i - Schwarz/Tan sport *Sold*
      '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
      • Ceeker
        • Sep 2009
        • 2821
        #33
        I have the suspected same problem; don't throw it out just yet. Cap the bottom opening and pour CLR - not diluted into the rad. Let it sit for a day. It should get the gunk and calcification out. it's worth a try before buying a new or used rad with the potential of happening again and a bottle of CLR and a little time is much less $$$$. I am going to do this in the spring as soon as the weather warms up? anyone getting -20 degree cold yet?
        Btw, Jlevie, I really like your input on a lot of the discussion and problem solving. :-) no I am not being sarcastic here.
        • audiquattrot
          • May 2008
          • 3836
          #34
          thanks for the tips. I agree jlevie and the ppl in this thread have been very helpful as far as problem solving.
          #snwmble
          Current:
          Past:
          • u3b3rg33k
            • Jan 2010
            • 2452
            #35
            +1 for CLR; it's amazing stuff.
            Ich gehöre nicht zur Baader-Meinhof Gruppe
            Originally posted by Top Gear
            Just imagine waking up and remembering you're Mexican.
            Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
            • payney8
              • Jun 2007
              • 899
              #36
              Get a t-kay test if you want to confirm the head gasket isnt leaking.
              • gearheadE30
                • Jun 2007
                • 3734
                #37
                Doesn't sound much like a head gasket to me. In that failure mode where there is exhaust gas getting into the coolant, the car will read as running hot, will get dramatically hotter under acceleration, and the coolant will often have air in it or will boil. Also you often will end up with a big cloud of coolant smoke on startup if the car sat for awhile.
                Sounds a little to me like a bleeding issue, but jlevie had it right, and you did tilt the car and such, so that's kind of ruled out. Aside from that heater switch, I'd point to either your clog or the t-stat. There is a chance that it was installed incorrectly or something, and the cold weather is masking temp issues. I had bad heat for awhile before I traced it back to air in the t-stat housing from a tiny leak, actually.
                Project M42 Turbo
                • Yonkers320is
                  • Jun 2010
                  • 15
                  #38
                  I have the same problem, no heat too. But in mine the heat dissapears when on the highway or anything over 30mph. In traffic jams or city driving the heat works fine. Changed HC and three thermostats, bleed the system like 5 times. I have no air in the system. I still think there is something wrong witht the thermostat, either too cold or broken. All from bavauto, will see if a local store has a different brand of T-stat....
                  I hear you can use water and vinegar to remove gunk from the radiator. as for using the garden hose to back flush the heater core, it should work, as long as the valve will let you fill the heater core with water......
                  • evil_twin
                    • Nov 2007
                    • 2965
                    #39
                    Is your coolant hoses going to the heater core correct?
                    Paypal: vdang5@gmail.com
                    Delta Auto Care
                    2875-C Towerview Road
                    Herndon, VA
                    703.435.1375
                    My Feedback Thread: Evil_Twin
