Reverse lights on constant
  • KEL
    • Dec 2010
    • 51
    The reverse lights on my eta just started coming on constant no matter what gear it is in when the car is running. It is a 5 speed if that matters. What would be a cause for this?
    I saw an Audi A6 with the same issue driving home yesterday lol.
  • E30m42cab
    • Aug 2009
    • 190
    The reverse switch on the tranny is probably jammed. Swapping it for a new one is a very easy job done underneath the car.
    • u3b3rg33k
      • Jan 2010
      • 2452
      Try going R-N-R-N-R-N-R-N a few times and see if they turn off.
      Ich gehöre nicht zur Baader-Meinhof Gruppe
      Originally posted by Top Gear
      Just imagine waking up and remembering you're Mexican.
      Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
      • EN318isPDX
        • Oct 2007
        • 4373
        I used to think that people were driving around with there reverse switch stuck but turns out its "rear fog lights" (in some cases like the audi)
        • u3b3rg33k
          • Jan 2010
          • 2452
          They're supposed to be red if they're rear fogs.
          • DaveSmed
            • Apr 2007
            • 1407
            Either way, rear fogs on without fog should be punishable by death.
            -Dave
            2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
            Need some help figuring out the ETM?
            • u3b3rg33k
              • Jan 2010
              • 2452
              Or at least moving target practice for other drivers.
              • jw 325ic
                • Sep 2006
                • 1360
                mine did this once, ended up the reverse light wire near the shifter got split and the lights stayed on. Reconnected the wires and that fixed it.
                • KEL
                  • Dec 2010
                  • 51
                  I will try some of the things suggested. Thanks guys.
                  • bimmerboy08
                    • Apr 2009
                    • 353
                    mine also had this problem, and it turns out that when I was doing some work in the center console I reconnected the male connector on the shift linkage with the wrong female connector going into the car. So if you have recently done any work down there you may have made the same mistake I did.
