Key wont turn to start position
  • riverdale21
    • Mar 2004
    • 786
    I have a 89 325i it's been driving fine. The past couple days when I put the key in to crank the car it will feel like the key is grinding on something as it moves to the start position. Today I drove to the gas station near my house and got out. When I got back in the key will not start the car. It will move almost to accessory, the check panel lights and stereo will come on but the window motors will not work. I thought it was a worn key but tried my spare... same result.
    What could cause my key not to turn all the way in the cylinder?
  • riverdale21
    • Mar 2004
    • 786
    Removed the lock cylinder using this guide: http://www.r3vlimited.com/board/show...light=key+turn
    Now using a flat head screw driver to start the car until I can replace it.
      You'll have to pull parts to figure out if the problem i the lock cylinder, ignition switch, or steering lock. Start by removing the ignition switch, since it dismounts easily.
      • StereoInstaller1
        GAS
        • 22679
        More than likely it isn't the switch, more than likely it is the section of steering column between the lock cylinder and the switch.
        It isn't all that hard to swap out except for the stupid little bolts that have no head. Get a dremel and a cut off wheel and cut a slot, then just use a screwdriver to pull the screw.
        GL!
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • riverdale21
          • Mar 2004
          • 786
          I'm more than certain it's the lock cylinder. I've got it removed and it clearly has something impeding the turning of the key. Even trying both keys it will not allow full movement. The car is functioning just fine without the cylinder, just using a flat head screwdriver to turn the ignition switch.
          Even with the lock cylinder in the column the steering wheel lock functions correctly and could be disabled by turning the key almost to accessory.
          Regardless if the lock cylinder is in the car or removed it wont allow the key to turn much further than accessory.
          • riverdale21
            • Mar 2004
            • 786
            Examining the lock cylinder there is a white block of plastic that slides back and forth. This is what was stopping the key from making it's full range of motion.
            Is this the steering wheel lock/switch you were referring to, Luke?
            • McGyver
              • 4636
              i've had the same problem for a few months now. its the damn lock cylinder that is getting jammed, but im using a screw driver to start it and turning the key to accessory to unlock the wheel and drive.
              • StereoInstaller1
                GAS
                • 22679
                Nope, the thing that the lock cylinder inserts into. It is the cast aluminum part that holds the steering wheel bearing, the cylinder and switch.
                You got lucky! Buy a new cylinder and get it keyed properly!
                Closing SOON!
                • riverdale21
                  • Mar 2004
                  • 786
                  That's the plan. Autozone said they could get me a key lock cylinder for $70 but it would be with their key. If I'm going to replace it I'd rather do it right and have a cylinder that works with my door keys.
                  Just out of curiosity what is that sliding white plastic block on the cylinder?
