Originally posted by jlevie
View Post
VIDEO: Not idling, super rough, no power
Originally posted by jlevie View PostUnfortunately that isn't true. I've seen broken rockers on M20's with automatic transmission that probably never saw over 5k (if that) in the life of the car. My theory is that the biggest contributor to rocker failure is a lack of timely valve adjustments. Excessive valve clearance causes impact loading of the rocker and that repetitive stress leads to failure.
should have put in a disclaimer: Im no m20 expert
Discovery?
I kind of knew about this "problem" but I'm not sure if it escalated to this.
That's my distributor cap. My rotors been rubbing on it, (rubbing equally I might say, it's a pretty darn even circle).
I don't know why it's rubbing, maybe I'm missing a spacer or washers or something?
Perhaps this could be it?
EDIT: Looking at the rotor, It says made in Italy and no cute roundel BMW puts on every single one of their parts. I'm guessing the previous owner (being the dumbass that he is) switched it out and put an incorrect rotor in.Last edited by lolcantturn; 01-23-2011, 08:35 AM.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+
Originally posted by jlevie View PostIs there spark when cranking the engine? If you have spark, what is the rail fuel pressure while cranking?
HOWEVER,
I do remember when I was driving it the hours before it broke down on me, on 1st gear when I went WOT, it kinda "bogged" at 3k-4k, then it finally recieved power at the higher RPM's. this was before all the awkward vibrations the engine made. My engine never bogged before so I dont know what that meant.
Only time will tell I guess, I'm moving awfully slow at inspecting everything since the weather is horrendous and will only get worse.
Originally posted by jlevie View PostIf you have spark, the next thing to look at will be the fuel system and then the injectors. Start by running the static fuel system tests in the Bentley manual.
Fuel pump works, and it pumps well coming out of the FPR.
The thing is, I dont feel the injectors working at all. No vibration or clicking, and its not just one of them, its all of them.
C191 connector looks good, not corroded. I cleaned them out with CRC cleaner, though I could probably do a better job, the connector still looked good.
I'm totally stumped... I've probably read "Fuel System" chapter of the Bentley 4 times already.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+
I have an 88 325is, late tailights and front and rear valances, but still diving boards. I think the build date is 12/87. I tried a stomp test, nothing happened, which points to either a bad TPS or I have the wrong Motronic..
Where can I buy like, a super tiny pipe cleaner so I can get inside the female connectors to clean them out?Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+
Maybe I'm doing something wrong, but both my 1st and 2nd cylinder injectors (the only ones I tested) are reading, ZERO ohms.
They also look like shit
But yeah, In recent days i've discovered that I'm not getting power to main relay points 86 and 30, nor am I getting power to the injector connector.
spark is there, fuel is there up to the fuel rails.Last edited by lolcantturn; 01-27-2011, 07:32 PM.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+
use 12v to try to switch the injectors. if they don't click... well. yeah. it does sound like they're shorted. I've never seen injectors read full closed loop.'84 318i M10B18 147- Safari Beige
Compression test:
I dont know how this could have happened. I've been running 3000+ miles on my cracked head, so I guess it finally gave way and that's why its not starting?
The results from cylinder 1-6 are:
50
65
70
70
90
85psi
Granted, this is on a cold cold cold engine that hasn't been started in 7 days in 28* weather.
Could this be it? Or maybe my compression was always like this? this is frustrating..
ok im losing it here
I changed out the injectors...twice
I cleaned every possible connection on the engine minus the C191 because it seems impossible to disconnect it
I'm getting fuel
I changed out the distributor and rotor
Im getting spark
My compression tests are in post above me..but I don't see why that would stop my engine from at least firing? none of my cylinders are firing
Rockers are fine..
im getting power to main relay
fuel pump works
CPS reads to ohm spec
Shit what the fuck......... I remember when my car was running and it was sputtering like in the video my check engine light turned on
On top of this I need a new breather tube from the valve cover, the cold litterally snapped it in half.
Could it be possible my timing belt jumped a tooth or something? This is extremely aggravating.
help please!Last edited by lolcantturn; 02-10-2011, 06:21 PM.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+
I know this thread isn't very uh..active, but I guess it'll be good if someone else has the same problem..
Discovery again..
Since my spark plugs are new, they must have some sort of coloring to them, right? I remember about 2 days ago my engine was trying to firing on some cylinders. Today, I checked the plugs to see which were new and which were old. To my SURPRISE, plugs 2,4, and 6 showed signs of ignition, while 1,3, and 5 were brand new!!
I know the E30 injectors are seperated into 2 banks, but I tested the injector connection and im getting voltage, and I changed out the injectors twice.
What could this possibly mean? I'm getting voltage to all injectors connectors according to the multimeter, and im getting spark to all plugs, but cylinders 1,3,5 are not igniting, while the other ones are.
This is kind of bittersweet because I finally feel one step closer to getting this thing going..Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+
