Cleaning Oil and Water wells during head gasket replacement
  • Massimo
    • Jan 2008
    • 3207
    Hi everyone i am replacing my head gasket and have cleaned the block surface with 3M Roloc pads.
    Now I crap all down the water and oil wells, I just want to know if there would be any issues if I was to poor kerosen down the wells to clean them out, then drain them out via the water and oil plugs?
    Dose anyone see an issue with this?
    Cheers Guys
  • !kid
    • 1362
    what about some kinda shop vacuum with a custom home built nozzle to fit into the water jacket openings? suck up all the crap that fell down in there. is the bottom end of themotor still together ? i would not advise putting other chemicals into the engine like that could cause harm to bearings, cylinder walls etc...
    :borg:
    • Massimo
      • Jan 2008
      • 3207
      I still have the pump and thurmo off so I am just going to shove a hose in there and wash it all out.
      As for the oil wells, a mechanic suggested to me once that if I wanted to clean all the carbon crap out of my car to put a bottle of kero in the oil run it for about 10min then drain and replace with new oil. So I am assuming that I should have no issues putting a bit down the oil wells to clean them out.
      • StereoInstaller1
        GAS
        • 22679
        I use a quart of ATF to flush a motor, don't know about kerosene.
        Closing SOON!
        Thanks for 10 years of fun!
        • Massimo
          • Jan 2008
          • 3207
          Maybe ill use that instead.
          Thanks
          • DaveSmed
            • Apr 2007
            • 1407
            Kero is ok for the oil passages, just leave the drain plug out and flush them. (Diesel is a bit cheaper I think)
            I wouldn't use it for coolant though. Open the block drain and use plain soap and water.
            -Dave
            2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
            Need some help figuring out the ETM?
            • browntown
              • Jun 2004
              • 3524
              ATF / Diesel / Kerosene / SeaFoam all the same shit = CLOUD of smoke
              • Ryann
                • 3350
                I lol'd. I have a shop vac attachment with a rubbery straw (that I obtained from a drink cup that a local Italian place served my kids a drink cup with) duct taped to it. Works great for drying out head bolt holes too.
