starter trouble:(
  • marshtgrade
    • 161
    starter trouble:(
    alright ill try to be as complete as possible in my description. bought the car,(88 325ic) ran fine 225k on it. car got crashed by mom:( bent tie rod, bumper was done, and some fender damage. other then that everything seemed intact. a week later the starter burns itself out. pulled it took it to kragen and got the confirmation that it wasnt going anywhere. picked up a starter refurbished put that in, fired it up work strong and perfect. lowered car to take off jacks tried to start and nothing. pushed starter it cause i needed to go to the store at the time. parked on a hill just in case after maybe 2 miles of driving. tried turning on right after i parked started up 3 times in a row no problem. shopped for about 3 hours then came back started up first time. drove the car with minimal to no problems for a week and now today when i woke up to go to work no start. just one failed crank, then no cranking. any ideas and/or suggestions? buying another car is out of the question btw college student
  • DaveSmed
    • Apr 2007
    • 1407
    "remanufactured" starters are frequently complete shit. Sounds like you got a bad one.
    On my SBC, I was going through the lifetime warranty remans every 1-6 months after the original lasted 14 years and 160k.
    Honestly, the best course of action on a budget is if you still have your old one, take it to a starter rebuilder and have it repaired and take that reman trash back. If not, I'm sure you could find someone selling an OEM one out of a car with reasonable mileage for cheap.
    -Dave
    2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
    Need some help figuring out the ETM?
    • gath
      • 577
      make sure the ground cable is bolted tight to the body.. cable from the oil pan to the body. Check that the starter wire connections are not loose.
      • marshtgrade
        • 161
        :d
        handled. damn that thing took me all day to get out the first time.(kinda my first time really working at something on the vert) took me 30 min to replace with a new lifetime warranty one:D
