wont rev past 2,500 rpm
  • 801coppertop
    • 293
    Here's the background its 3 degrees outside. I warmed up my car for a good 7 min. When I went to accell the throttle was cut at 2,500 rpms. Could it be from frozen gas? I thought the freezing temperature was way lower. Any thoughts. Also it did it weather or not i was in gear.
    Update: after about ten more minutes of idling it finally got up and went. Hmm.....
  • immajackuup
    • Dec 2010
    • 1132
    damn you got them 2 step set up,sweetttt.
    • 801coppertop
      • 293
      2 Step setup? What you talking about Willis?
      • immajackuup
        • Dec 2010
        • 1132
        • 801coppertop
          • 293
          lol no its not like that, its a lot less fun...
          • 801coppertop
            • 293
            No help.......?
            • elmercc
              • Feb 2011
              • 129
              Its possible you could have water in your fuel line, causing it to freeze as a higher temperature than gas is supposed to freeze. They sell additives at AutoZone or any other car place that gets the water out of your lines....might try that!
              (OO=[][]=OO) 1990 325i
              • 801coppertop
                • 293
                Awesome i will, is it just a fuel additive?
                • EGoman
                  • 102
                  My 320 m20 -88 does exatly the same even tho my car is in garage (+10deg) and outside has about -2 degrees. Haven't had a time to search problem.. If you find out do tell :)
                  • HST
                    • Jan 2006
                    • 757
                    A failing TPS can cause this.
                    Originally posted by KingB
                    Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
                    • LJ851
                      • 7919
                      My car did exactly that last year. It was the crank position sensor. ( 1989 car)
                      Lorin
                      The M30 is God's engine.
