Removing trunk sound deadening.....
  • etajohn
    • May 2005
    • 79
    Two things: Wow that stuff is heavy. Wow what a pain. My '87 eta has TWO layers of the stuff. Last night I got out the top layer and it felt like 25 pounds in the bag when I threw it out. It is a sticky and time consuming job. I attacked it with a wood chisel and a hammer and every so often I could get hold of it with my hands and rip out a big piece. I also poked a hole in my trunk floor with the chisel. Bahh! Anyway, I drove the car around after I was done and it didn't seem any louder. We'll see what it's like after I remove the second layer. I can't believe that BMW felt it so important to put 50 pounds of this crap in the trunk when I just had my interior door and rear seat side panels off to repair two dents and found almost nothing in the way of sound deadening there. And to answer any questions about why I'm doing this, yes, I want to remove the weight from my car. Yes, my dead AC compressor is coming out too so my weight balance should stay the same. And, either way, I don't care if the weight was put there for some other reason. I don't believe adding weight to be a good thing in respect to performance. A lighter car is faster, gets better gas mileage, turns and stops better, and puts less strain on the consumables like bushings and tires.
  • AdamF 88iS
    • 2051
    Ah, but your last statment is wrong. A BALANCED car, even if it's a few lbs heavier, will handle better.
    But like you said, your AC is coming out anyway so you'll be fine.
    Anybody who's cared to pay enough attention or knows how to drive worth a damn will notice right away that the car will oversteer more with just the slab out and no counter balanceing mod done in the front.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • ///M Powered
      • Jan 2004
      • 1109
      I took the sound deadening from under my back seat, came out really easy with a blow dryer/ scraper ;)
      • erik325i
        • Jan 2005
        • 3567
        I removed my trunk tar with a crowbar and a hammer. Don't worry about my weight ballence... I made up for it with two subwoofers and two amps in the trunk. :P
        • Nathan
          • Apr 2004
          • 671
          My sound deadening in the trunk was easy to remove and came out in three pieces. Took me less than 5 minutes... :twisted: Guess there is a difference between the early vs later style trunk sound deadening.
          PNW E30 CREW ///
          • etajohn
            • May 2005
            • 79
            Are you talking about the carpeted pieces? We are talking about the 40 pound slab of tar bonded to the trunk floor of six cylinder cars.
