Car can't drive when cold. only once warmed up. Misfiring when Warm....
  • Draco02
    • Feb 2011
    • 28
    #91
    Matt-B
    Do you have another spare coil I can get to fix my car? Trying to swap out a confirm good coil pack.
    Dracoruno@gmail.com
    Thanks
    • fiftytakedowns
      • 2460
      #92
      Its backfiring hardthrough the intake and in the exhaust If I leave my goot on the gas while it's boggin.
      [/url]
      Team USA Wrestling 67KG
      • Danny
        • 14216
        #93
        I would bet a large amount of money the timing is off.
        • fiftytakedowns
          • 2460
          #94
          The timing system is perfectly lined up. I have pictures as well.
          [/url]
          • fiftytakedowns
            • 2460
            #95
            Some of them look off because of Camera angle is not straight on.
            [/url]
            • trackjunkie21
              • Jan 2010
              • 3962
              #96
              spark plug wires on wrong?
              Originally posted by Wh33lhop
              VANOS: sometimes you just need to go full retard.
              • fiftytakedowns
                • 2460
                #97
                It's Coil on plug, that being said, Why would it drive normally when it's warm?
                [/url]
                • fiftytakedowns
                  • 2460
                  #98
                  What would I expect to pay if I were to take it to a mechanic?
                  - should I start throwing brand new parts at it and take it from there?
                  I mean if it's spitting a camshaft sensor code, maybe thats a good place to start?
                  Despite the crankshaft sensor reading .560 ohms and the camshaft 1.250 ohms.
                  thanks.
                  And one of my ECU's nearly burnt my hand after handling it.
                  [/url]
                  • fiftytakedowns
                    • 2460
                    #99
                    Fuck this Motherfucking thing,
                    So now, After doing 2 70 mile trips, on a good ECU, now it's misfiring again. sometimes It seems to be load dependent others it Seems like its RPM dependant. but it is DEfinitley affected by having my foot on the throttle, and it is acting like it's hitting a limiter or spark cut. The trip was a living hell.
                    [/url]
                    • JakeP
                      • 315
                      #100
                      Take it to bmw?
