Making a jumper wire for toolbox
  • kinvodA
    • Sep 2009
    • 278
    I want make a jumper wire to keep in my tool box, is there a specific sized spade to use for both ends? Should I make more than two ends to test multiple things at once? Is there a DIY specific to making the "Ultimate E30 Jumper Wire"
    "Wow. We're just blowing through nap time, aren't we?"
  • FredK
    • 14759
    I've found using 1/4" spade terminals is fine for making a cable to jump relays.
    To jump some relays it may help to have a 3-spade jumper cable, but make sure you have some kind of insulating cap to prevent shorting of the third spade when it's not being used.
    • kinvodA
      • Sep 2009
      • 278
      Maybe I should make one with two ends and another with 3 for when it's necessary. Would I just splice all three lines at a common point or have two ends next to each other with the third end on the opposite side?
      • lole30
        • Jun 2010
        • 29
        get your self a box of t-pins
        They are like $2 at the sewing section in walmart for a box of 40. That will allow you to tap into any connector with or without unplugging it.
        then order yourself some test leads. you can also get them at any auto parts store. you can also buy the alligator clips alone and make as long of a jumper lead as you need.
        http://www.harborfreight.com/catalog...y=&q=test+lead
        that will jump any combination of wires together you need.
        • DaveSmed
          • Apr 2007
          • 1407
          I love these things!
          -Dave
          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
          Need some help figuring out the ETM?
          • elmercc
            • Feb 2011
            • 129
            May I be so uneducated as to ask what you would use these aforementioned items for? :-)
            (OO=[][]=OO) 1990 325i
            • kinvodA
              • Sep 2009
              • 278
              The idea is that I could bypass/diagnose a faulty relay
              • lole30
                • Jun 2010
                • 29
                ding ding ding ding.
                can also find opens and you can give ground or power to any component you might need.
                a very good and inexpensive electrical tool is the power probe III.
                $100 on ebay.
                • rammstein
                  • Jul 2009
                  • 367
                  Those Walmart things are simple genius. Thanks for the tip!
                  E30 M52B28
                  • b*saint
                    • 3794
                    I use alligator clips on both ends. Then if I need to use stakons, I just stick on uncrimped non plastic boot stakons to whatever and then clip to those.
                    Ma che cazzo state dicendo? :|
