RAM Intake or not?
  • armeN
    • May 2005
    • 327
    RAM Intake or not?
    Decided to upgrade my intake for shits and giggles. Need some advice. Should I go with the cone K&N Filter or the RAM version? Check these out:
    http://www.seambmw.com/e30intake.htm (Bottom one)
    http://cgi.ebay.com/ebaymotors/ws/eB...66413&rd=1
    http://cgi.ebay.com/ebaymotors/ws/eB...77380&rd=1
    Either way I will have a headshield so that's out of question. Thanks.
    I go wuaaaaaahh pssssshhhhh!!!!
  • Stu Mc
    • 4083
    Ram?
    What are the goals with this system? I hope horsepower isn't high on the list.
    • Ryan Stewart
      I Love Miatas
      • 8978
      All of those do the EXACT same thing. Make the engine louder. Nothing else. So just go with one that fits.
      Im now E30less.
      • trent
        OMFG GET RAM AIR ITS TEH BOM!!I put anotehr 12 HP on my 318 with RAM AIR!!
        • DanGillan
          • Mar 2004
          • 4061
          you absolutely cant survive without the 3rd one, so make sure you get that one, it is FAR superior to the rest. make sure you buy it and dont listen to anyone elses opinion.
          Dan
          • armeN
            • May 2005
            • 327
            I'm hesitant about the foam filter. Any advice on if the foam filter is better or not?
            • DanGillan
              • Mar 2004
              • 4061
              ITS SOOOOO much better, seriously, foam is the way to go, they are proven to be about 4 or 5 horsepower more than K&N's. you should buy it, definately, its been proven, tested specifically on e30's.
              Dan
              • golde30
                • 11464
                oh man, im dying over here....its just mean. :twisted:
                IG: @Baye30
                • erik325i
                  • Jan 2005
                  • 3567
                  None of those are "ram" air intakes. The only thing different between them, is the little piece of tubing that goes between the AFM and the filter. The tubing helps because it makes the air less turbulent going into the AFM. Don't get the one that bolts the filter straight to the AFM.
                  • Mystikal
                    Wheel Fitment Expert
                    • 9602
                    You seen M20 dyno charts proving that?
                    • erik325i
                      • Jan 2005
                      • 3567
                      I have not seen any dyno charts proving this, but it is the same reason there is a "velocity stack" in the stock airbox. Why would BMW put this tube inside the airbox that goes almost all the way to the other end of the box, which would even look like it limits airflow? The answer, my friend, is to reduce turbulence.
                      • rwh11385
                        lance_entities
                        • 18403
                        I'm going to have a RAM air intake.....to the stock airbox...to a M30 AFM.
                        who is joking?
                        • armeN
                          • May 2005
                          • 327
                          little peice of tubing or no little peice of tubing?
                          • randomtask37
                            • 3154
                            get a k&n filter from advanced auto parts and put it into your airbox. thats about the best your gona get.
                            if u wana get real fancy u can cut the bottom of your air box off. that way u have one big open side for air to come in. i felt a smallllll difference when i did it. but that car defintally sounded meaner.
                            98 M3/4/5
                              • 37829
                              Buy the one without the little tube and buy my LukasBMW heatshield to go with it
                              Classic BMW Specialists
                              Grover Beach, CA
                              www.BimmerHeads.com
