oil service light
  • rede30
    • 4697
    oil service light
    my oil service light wont go away. i have used the wire trick to the correct pins and that has worked for a few times but this time it will not work. What coudl i do to make these devil lights go away. thanks
    Dustin
  • AdironRider
    • Dec 2004
    • 3491
    The one on your dash or the one on the overhead idiot lights. The oil light in my car on the overhead one wont go off even though everything is ok. Any ideas on what could cause this?
    Back to my roots
    • erik325i
      • Jan 2005
      • 3567
      Same as my car. The oil level sensor is bad. I need to replace it.
      • rede30
        • 4697
        its the light on the dash. it says oil service and the colors yellow and red are always lit.
        • Bimmerfanatik
          • May 2004
          • 5349
          Re: oil service light
          Dustin
          One possibility is the SI board batteries are going. Might need to replace them.
          Try the search feature for questions like this - they've been asked by previous members, so you'll find the answer easily :)
          PS - the oil light on the dash itself may come on if your oil sensor went bad - happened to me in my Euro - revved and it went away. People told me it was a slew of things, someone mentioned the $6 oil sensor, sure enough, it cured the issue. Go buy one new, and throw it in next time you're under there doing an oil change.
            • 34847
            sounds like dead SI board batteries to me.
            • e30325ic
              • Dec 2004
              • 491
              Have you tried to reset it? If you reset and it come right back on then the SI board batteries are bad but it my just need to be reset.
              1990 E30 325ic (sold for more than I paid for it after 5 Years)
              1995 E30 325e (in progress)
              1987 E30 325is (totaled)
              1990 E30 325i
              1991 E30 318is M50 PWR
              1996 E36 328ic
              1997 Z3
              2006 F150 Super Crew 5.4L 6.5' bed The work horse (need something to drag all these old BMW's home for resurrection.)
