What cars did the 3.46 LSD come in?
  • Lof8
    • Oct 2006
    • 2827
    e28s was it? Do they need modification to mount in an e30? My S50 swap car is currently running a 3.73 LSD. I don't like the high rpms at highway speeds, I have to do a lot of quick 3-4-3 shifts at Sebring, and I'm on the rev limiter a lot at autoxes. So, I'm hunting for a 3.46. Help me find one.
    Thanks
    S50'd
    Originally posted by TDE30
    What is this faggy shit I have happened upon?
    I can always live in a M3. Can't M3 a house.
  • FredK
    • 14761
    Some E28s came with the 3.46.
    They require no modification, except to swap your E30 rear cover and output flange to the diff. The output flanges are easy to remove and reinstall. Use a prybar to pull it out, then push the E30 output flange back in until it clicks.
    • M-technik-3
      • 18946
      Some e24 635's did as well.
      • BenM
        • 2184
        IIRC they came in some late E28 528e (1988/Super ETA only) and late E23 735i's (85-87). As Greg said also the E24s, but I think it was just the '88-89 Automatics.
        Originally posted by BillBrasky
        E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
        1991 318i Alpine II - S50/5-lug swapped - track car
        1989 325i Cirrusblau - Daily
        1970 2500 - Malaga over Grey Cloth
        2012 F350 6.7PSD
        • M-technik-3
          • 18946
          Duh forgot E23's that is where mine came from.
          • StereoInstaller1
            GAS
            • 22679
            Thanks
            What trans you have in there?
            Closing SOON!
            Thanks for 10 years of fun!
            • 5ickride
              • 2922
              Same issue here, 1st gear is practically useless. Im hitting 5k RPM's at 90mph on 5th gear, haha...but boy that engines sounds so nice! I got a 3.46 lsd sitting at home that will probably get installed soon.
              • Lof8
                • Oct 2006
                • 2827
                I'm using the G260
                Let me know if you decide against installing it.;)
                S50'd
                • M-technik-3
                  • 18946
                  3.25 lsd isn't bad and is more common than a 3.46.
                  • Lof8
                    • Oct 2006
                    • 2827
                    Hmm, have you used a 3.25 in a swapped car with a G260? Whats the cruising rpm at about 80mph?
                    Edit: Nevermind, some seraching leads me to believe that a 3.25 will work well for me.
                    S50'd
                    • Supadave
                      • 1006
                      What rear end do you have?
                      https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
                      • M-technik-3
                        • 18946
                        Behind a 0.81 getrag 260 It might not be the best combo but 5th gear cruising will be great on fuel.
                        • StereoInstaller1
                          GAS
                          • 22679
                          I have an S50 sitting that is go in front of a 260, and I have a 3.46 sitting.
                          I expect to have news about it this year...
                          Closing SOON!
                          • LJ851
                            • 7918
                            E28 535is AUTO-TRAGICS are also blessed with 3.46 slips. My schnitzer 3.7L M30 powered E30 had a 3.25 and it was nice on the highway but i think a 3.46 would have been better. Honestly, BMW first gears are so low you are going to have traction problems no matter what rear gear you choose if you have some HP. I couldnt even put 2/3rds throttle on the ground in first with mine.
                            Lorin
                            The M30 is God's engine.
                            • e30_luv_
                              • Jul 2008
                              • 186
                              Scouring Craigslist I found a "supposed" 3.46 LSD that came out an e36 318is. Did the 3.46 LSD come out of the e36 too?
