Electronic bug - No blower, no tach
  • Hick
    • Sep 2005
    • 6451
    New electronic bug. 88 325is chassis, 91 318is drivetrain/engine harness
    On start up the blower motor, tach, fuel and temp gauges work for about 3 seconds then shut off.
    Ive checked both unloader relays, k5 and k7. If i hold k7 closed then the blower works, but thats no solution.
    This happened all of the sudden, the car was fine the day before but when i went out the blower/cluster quit working. No signs at all, ive had this car in this configuration over 5+ years.
    Speedo still works, interior lights work, radio works.
    Originally posted by vlad
    • 34837
    does everything work if you hold K7 closed or just the blower?
    • Hick
      • Sep 2005
      • 6451
      just the blower with k7.
      i did a quick google search 'e30 blower motor tach temp fuel' and found a bimmer forum thread... fuse 10 fixed it!
      • Hick
        • Sep 2005
        • 6451
        bump, popped again. time to dig out the schematics... awesome
        • Brian 89 325i
          • 1450
          Does it blow when putting the car into reverse? I had that same problem, turned out to be the wires that run through shift boot (the rubber boot) were frayed and shorted.
          hth
          -Brian
          • Hick
            • Sep 2005
            • 6451
            hth
            -Brian
            Maybe, ill have to look.
            I dont use the ebrake so its in reverse when parked
