CA Smog FAIL - HELP!
  • Lensolo
    • Jul 2009
    • 70
    Failed AGAIN. Hoping you guys could tell by the numbers where I should begin with getting the car to pass. ANY info is greatly appreciated.
    Thanks!
    Len
  • reelizmpro
    • 9552
    Scan of the actual smog results would be helpful. What failed?
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Lensolo
      • Jul 2009
      • 70
      Great idea. Thanks, Barry.
        That combination suggests that the catalytic converters are bad. But before replacing them you should make sure that there are no intake leaks and the everything in the engine management system is working like it is supposed to.
        • devon.818
          • Feb 2011
          • 2937
          i used to have a LeBaron with a blown head gasket, the guy hooked all the shit up then started to warm up car, obviously it was blowing smoke all over, i played dumb and said "so you think it will pass?", he said, "*laugh* uhhh NO!"
          so i looked at him and..."DUDE, if that shit doesn't pass i'm not fucking paying you"
          him-"what?!?!?!"
          me-"why the fuck would i pay if it didn't pass?"
          him-"ok ok ok"
          he made it pass :D.
          just bribe someone. cough cough
          • reelizmpro
            • 9552
            Jim,
            NO is really low at 25mph though, which suggests the cats are good and perhaps not hot enough. HC are both high though. The car is running rich and he has some room with the CO. So he needs to lean it out a bit and get the cats nice and hot. What car is this? 325i?
            88 M3 - LACHSSILBER
            • Lensolo
              • Jul 2009
              • 70
              Jim,
              How would you suggest leaning the car out? It is a 325i.
              • iwantspeed
                • 3164
                drive the car hard before running the smog test again
                get a tank of 91
                oil change oil filter
                throw a new air filter on there.
                and maybe some ecu temp sensors
                and an o2 sensor
                temp sensor is around 20
                o2 is around 90
                air filter 20
                oil around 20
                oil filter around 10
                full tank of 91 around 55
                rmeuropean.com
                pelicanparts.com
                has all of those goodies. too.
                i would do that if you have some cash to get it running right
                maybe have a shop do a smoke test and see if you have any vacuum leaks.
                Project
                Parts for Sale
                Feedback
                YouTube Channel
                • iwantspeed
                  • 3164
                  my smog results post 232
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
                    Jim,
                    I would agree, except that the NOx is high at idle. The engine may be running rich, but the high HC could as easily be from misfires on a lean engine. The high NOx says that the engine is lean or that the catalytic converters aren't working properly. If the engine had run long enough to reach normal temperature and the catalytic converters were good and the mixture was normal with no misfires the NOx level would be much lower.
                    HC & NOx are higher than normal at 25mph, though within limits. The high HC could be from the DME increasing fuel trim to compensate for intake leaks, which have a greater affect at idle, and/or an aged O2 sensor. But the high NOx points to the catalytic converters. The catalytic converters aren't completely dead, but they may be damaged and not functioning as they should.
                    • reelizmpro
                      • 9552
                      Which is why he should definitely do a tune up, check for vac leaks and other maintenance to try an rule out these factors. It's cheaper/easier than changing the cats. Plugs, universal O2 sensor, filters are all pretty cheap if he hasn't changed them already.
                      88 M3 - LACHSSILBER
                        Absolutely. As I said in my first post before replacing the cats make sure that everything else is right. At the minimum I would:
                        Have a smoke test run on the intake and fix any leaks found.
                        Run the fuel system test suite in the Bentley and repair as indicated
                        Replace the ignition wires, rotor, cap,and plugs (with NGK or OE)
                        Replace the O2 sensor
                        Adjust the valves
                        Verify or replace the ECT sensor
                        If the car has 150k (or more) on it I'd also have the injectors cleaned and flow tested.
                        • Lensolo
                          • Jul 2009
                          • 70
                          Adjust the valves
                          Thanks so much guys for all your input! All great suggestions. I'll start with the basic tune up procedures and report back. The car has 2xx,xxx miles on it. ODO stopped at 256,000 a year ago.
