Throwout Bearing
  • SpiritualPlum
    • Feb 2011
    • 40
    Throwout Bearing
    So for the past few months my throwout bearing has been making a noise whenever the clutch is depressed. Previously, it was only a slight grind sound that, although annoying, didn't seem to be too big of an issue. Today, on the way to work something must've happened to it, because now when I press the clutch it screeches, and the clutch pedal doesn't feel right at all. Is it safe to drive it to work like this tomorrow (30 miles) and fix it this weekend, or is the screeching something seriously bad for my clutch? Also, are there any parts I need besides the bearing when fixing this? And if anybody knows how to change the bearing, help would be appreciated.
    Just tryin' to feed the e30 need.
  • Cletonius
    • 2809
    odds are the screeching is part of the TOB rubbing on the bellows. I had a similar sound in my old turbododge when the TOB disentegrated on me. I personally wouldn't drive it.
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
    • scottinAZ
      • Dec 2009
      • 1312
      tob is shot, and is kiling the pressure plate fingers. dont drive it unless you WANT to be stuck in a gear. replace entire clutch, and be done with it. labor is the same either way, tob and pressure plate are already shit, so just do it all while in there
      I saved 15% on my Bimmer parts by switching to ...
      • SpiritualPlum
        • Feb 2011
        • 40
        The clutch barely depresses enough to shove it into gear. Poor car is parked until I can get to my shop next week ):
        • hotghias
          • Jan 2004
          • 148
          Yeah, don't do what I did, which was ignore the sound and have your TOB explosively fail on a boat ramp, then have to get it towed to a shop for a $750 clutch job.
          • MaxBell
            • 1391
            Yes, I had this exact same problem with my 325i. I bought the super clutch kit off PelicanParts.com. It's like 300$ or something, free shipping within the US and has EVERYTHING that can be replaced when you're pulling the transmission out.
            GIT ER DONE.
            REMEMBER: Be safe and have fun is Rule Number 1.
            The Epic Unbuild of Clint Eastwood
            • SpiritualPlum
              • Feb 2011
              • 40
              Called and got an estimate of $850 parts and labor. I also have to find out what month my car was made in, as apparently if it was made before a certain date, I need to order a clutch that will take 3 days to get here, and if it was made AFTER that day it'll only take like a day to fix...? FUCK, I can never just get a car that works. I want to sell this e30 and buy a nice rust-free one...
