Help me pass emmissions r3v!
  • lolcantturn
    • 4588
    Finally got my E30 working pretty darn well. Compression in the cylinders are 150+ across the board, fixed a lot of half-ass-ness I did when I first replaced the head in november, spliced the C191 connection cause it was corroded to shit, never goes passed the halfway mark on the temp even on long idling sessions.
    Took my E30 to inspection today so I don't get more tickets. I finally passed..erm..well, "High Idle," but I failed regular idling. I was running my car on 1.2gallons of gas, 1/2 gallon of denatured alcohol (all taken out of the system now).
    My idling HC PPM is retarded high. Check it out
    Let me know what I can do r3v! Car runs great, except, idle is a littleeeeeee shaky. Definately not running on 5 cylinders shaky, but just a tad shaky. When I stomp my foot to the floor there's a slight hesitation, quite minor. I have a check engine light as well. I can't do a stomp test (153, darn).
    Originally posted by TSI
    OEM+
  • wodcutr
    • Apr 2009
    • 2193
    Make sure your TPS is adjusted properly. I had a car that had the same issue and the TPS was never telling the ecu you were at 0 throttle. Makes a huge difference!
    The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
    • colorado_cabrio
      • Sep 2009
      • 891
      this
      • lolcantturn
        • 4588
        Originally posted by colorado_cabrio
        this
        Word! I'll get some CRC cleaner (mine ran out) and clean that bizznatch out
        OEM+
        • LJ851
          • 7919
          It is very simple to check adjustment and operation of the switch, dont spray first and ask questions later.
          Lorin
          The M30 is God's engine.
          • lolcantturn
            • 4588
            the TPS is actually reading nothing when I connected my multimeter to terminal 2 and 18 and opened it slowly, and then 3 and 18 and opened it slowly. nothing at all..
            OEM+
            • LJ851
              • 7919
              You have your meter set to read ohms , right? what year/model do you have? You are testing the TPS while it is unplugged?
              Lorin
              • lolcantturn
                • 4588
                Yes of course:grin:, 88 325is (153 DME, diving boards, late valances and late rear lights), and yes I took the whole TB out.
                OEM+
                • LJ851
                  • 7919
                  Sounds like you are doing it right. 2-18 should have continuity (0 ohms) when the throttle is closed, 3-18 should have continuity (0 ohms) when throttle is is almost wide open. Sounds like a bad TPS if you did the tests correctly.
                  Lorin
                  • lolcantturn
                    • 4588
                    Shucks. I'll double-check the test again. If it's still not reading anything I'll just get another TPS
                    OEM+
