Stupid Idiot Retard Dumb Battery Mistake
  • Pussy30
    • Feb 2011
    • 463
    Okay long story short I had to take my battery out to jump a stranded vehicle I couldn't reach with my car. I took my battery out. Jumped it. But the battery isnt the right battery for an e30 and the contacts were backwards. So I installed it the same way every other e30 battery is installed and sparked the shit out of it. I ended up buying a new battery but now the radio and tach aren't working and from a quick look the fuses are intact.
    Fuckkkkkkkkkkkkkkkkkkkk
    SOS
    HALPPPPPP
  • CabrioPunk
    • 1451
    ECU may be fried? Need radio code.
    • Pussy30
      • Feb 2011
      • 463
      It was running. Then the battery drained over night so I put it on the charger and tried starting it and all I got was a loud buzz from under the drivers side dash when the key is turned.
      • Pussy30
        • Feb 2011
        • 463
        It was fuse 21
        Thanks though.
          • 37833
          You got lucky.
          Grover Beach, California
          BimmerHeads.com
          • Pussy30
            • Feb 2011
            • 463
            Originally posted by MR 325
            You got lucky.
            Very lucky
            But then my tranny went. my luck
            • Smelser
              • Feb 2011
              • 633
              Speaking of lucky, I was cranking over the 318 that was in the barn for over a year, had the charger pumpin some serious amperage to it. It would kinda start but die and I heard some ticking, found out the wires were bad, re-routed them (I didnt like how the guy had the coil lead running and laying next to two cyl wires) when I did that the coil wire grounded out and jumped to the strut, THATS NO GOOD. lets put it in the air and crank it again, then BOOOOOOOOOOOOOOOOOOOOOM the battery explodes and sends acid all over the front of the car, and me on the other side, coating my eye. my friend standing only inches from the battery, had nothing!! FLUSH, hospital, optomitrest. WOW, you have had a lot of stuff in your eye, its very scared, but they both look good!
              That is lucky!! car parts can be replaced at a cost, your body is forever!!
              sigpic1984 318i Total conversion to a DIRT race car.
              Check out our build on facebook @ www.facebook.com/brewstermotorsports
              • Bene
                • Feb 2011
                • 358
                look on the bright side: worst case scenario, you get to wear an eye-patch.
                • M-technik-3
                  • 18946
                  Battery was frozen?
                  • Alpine30 Wolf
                    • Jan 2011
                    • 384
                    better then puttin a 40 fuse in a 7.5 and fryin basically every wire and screw your electricals.
                    Strategic Alpine Command
                    • billybobjoseph
                      • 213
                      Loud buzzing is probably your abs relay.
                      • Pussy30
                        • Feb 2011
                        • 463
                        Everything is fixed now btw
                        • jasonsnoddy
                          • 1900
                          Hahahahahahahahahahahahahahahahahahahahahahahahaha hahaha
                          Originally posted by stewie30luvr
                          ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
                          Originally posted by JakeP
                          with a coathanger
