Speedo pulse sender - Differences??
  • BlackSpeed66
    • Apr 2008
    • 624
    Spending this lovely St. Patty's day in the midst of a diff swap. The diff being swapped in is a different ratio from a later model and the plastic pulse sender was damaged in shipping. It has a different style connector than the one on my car (presumably original). They both fit the diff the same, but my question is will there be any issues with speedo readings or otherwise if I used the original sender with the newer diff? RealOem shows different part numbers for each but that doesn't necessarily mean they function differently right?
    Thanks!:drink:
    -Geno
    '87 325is (s52'd)
    '95 525iT
    '95 Jaguar XJR-6
    '02 Range Rover 4.6 HSE
    '98 Disco 1
  • nrubenstein
    • 3148
    If the sensor length is the same, it'll be fine.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Pussy30
      • Feb 2011
      • 463
      My god there was a thread on this like 2 days ago.
      • BlackSpeed66
        • Apr 2008
        • 624
        Your point? Nothing useful showed up in a search, so I asked a question. That's what this board is for right?
        -Geno
        '87 325is (s52'd)
        '95 525iT
        '95 Jaguar XJR-6
        '98 Disco 1
        • benyen soljax
          • Mar 2012
          • 290
          Thread resurrection...after you swapped the diff, was your odometer reading screwed up? I went from 4.10 to 3.73 after my manual swap and now I seem to find my odometer reads 25% high.
          Project 325is
          Transaction Feedback
            • 34847
            odometer has nothing to do with your diff ratio.
