turnsignal switch removal?
  • chop_suey
    • Nov 2009
    • 270
    does anyon know if the steering wheel has to come off to remove the lower steering column cover?
    thanks
    85 325e 5spd
    I think the bottom cover will come off w/o pulling the steering wheel.
    • shiboujin
      • Feb 2006
      • 2791
      the lower cover comes off easily if you take off the kick panel. You need to take off or cut through the top though. So yea, you'll probably wind up taking off the steering wheel.
      • chop_suey
        • Nov 2009
        • 270
        ya it looks like there are sone tabs on the wheel side
        85 325e 5spd
        • MattM
          • Apr 2009
          • 931
          usually you can break the plastic away pretty easily if your just going for the stalk at a pick and pull or something... you'd be lucky to have the keys
          Full Build Thread Here
            • 37828
            It would be a good idea to take off the wheel.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • bernzpeed
              • 3917
              take off the wheel because there are 2 screws that you need to undo before you can take the stalk out.
              89 E30 S52
              Transaction Feedback.
              • chop_suey
                • Nov 2009
                • 270
                ok great thanks, just wanted to make sure sos i dont break it
                85 325e 5spd
