SI Board battery replace I searched
  • 36brua
    • 689
    86 E and 89 I I'm replacing bulbs and want to do the batteries.
    I've not removed the cluster from the dash yet.
    search keeps coming up with 2 different choices
    Nicad 2 ea radio shack #23-191 1.2v AA
    or sanyo 3v cr14250SE
    any help here? or just go take the cluster out first and see whats there
    Thanks
    My CA legal M60 swap
    The happening in our garage
  • Simon S
    • Oct 2004
    • 3758
    Jean will probably chime in - he knows his way around the different gauges..
    Likely best off pulling cluster and replacing what's in there.
    two CR14250SE batteries when in my late model VDO gauge fwiw
    If I had to do it again - i'd just buy a new board if I could swing it. (although, they are kinda pricey these days)
    I had a hell of a time replacing batteries.
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • 36brua
      • 689
      Thanks? for the link to your battery replacement experience!.
      one way or another the board has to come out I'll flip a coin then to replace or buy exchange.
        • 34844
        early SI boards use nicad batteries. late ones use lithium cells. they aren't cross compatible.
        on your '89, first measure the voltage on the batteries. if it's at least 3v, they're fine. don't mess with them. the batteries are only drained if the car's main battery is disconnected. this also means you should be careful leaving the battery disconnected for long periods of time. mine are original and still have full voltage.
        • matias88e30
          • Dec 2009
          • 1110
          Hope it gives u an idea
          no more boosted m20, 91 318i...
          • 36brua
            • 689
            well ok.. I'll keep repeating that over and over as I'm plugging my soldering iron in in..:)
            Agreed start with a visual , the VM and go from there
            thanks
            • 36brua
              • 689
              Originally posted by matias88e30
              Thanks found / read that article when I was searching for info
