selector rod joint replacement
  • mkcman17
    • Jul 2010
    • 8240
    I'm re-doing the bushings in my shift linkages, and have taken care of them all minus the output joint from the trans to the selector rod. I have the retainer removed,but there is a pin or something keeping it from coming off. Also, my new joint is narrower and doesn't fill out the selector shaft arm. How do I get the old one off, and is my new joint going to cause me problems?
    1989 LN106 Hilux / 3.0TD SFA
    1974 2002tii / stock
    2002 IS300 / 5spd LSD
  • Simon S
    • Oct 2004
    • 3758
    Well - first, here's a pic of when mine came off. Yes - there is a pin.
    As far as the selector shaft arm and transmission joint - sorry - I suspect that is an early/late model-specific selector and joint combination issue that I'm not familiar with.. or maybe it's a m20/g260 vs m42/g240 combination issue.
    Late model with m42/g240:
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • mkcman17
      • Jul 2010
      • 8240
      Awesome post and awesome pics!
      Looks like my little joint is for an m42. Sucky. I'll just get one from the dealer tomorrow, because I need to grab the rear carrier anyways.
      How does the pin come out?
      • Simon S
        • Oct 2004
        • 3758
        Without retainer clip around joint - the pin should slide out.
        Think I pushed pin down/out from above with one of those 'dental pick' tools that are hook-shaped.
        • mkcman17
          • Jul 2010
          • 8240
          Hmmm I tried that and it didn't seem to budge, but I guess I'll try harder. I didn't realize how expensive the joints were, I may just go solid selector..
          • george graves
            • 19998
            Originally posted by Matt-B
