oil pan question
  • matias88e30
    • Dec 2009
    • 1110
    oil pan question
    Whats up! i have a boosted e30 and the oil pan its leaking, is there any good silicone i can use to seal it, or just replace oil pan gasket AGAIN?
    any suggestions would help!. Thanks in advance
    Matias.
    no more boosted m20, 91 318i...
  • Pussy30
    • Feb 2011
    • 463
    Get a good gasket, ptex it up, and torque it down correctly.
    • 240zs30
      • 583
      why not just replace it? I have one and I'm local.
      • matias88e30
        • Dec 2009
        • 1110
        i have a spare oil pan a a new gasket already. Thanks tho bro ^^
        waffleswaffleswaffleswaffleswaffles30: any good silicone u would recommend? i dont want to use the cheap auto parts one, bad experience with it already
          • 37833
          Use a paper gasket, not cork. Do not use silicone!!
          Grover Beach, California
          BimmerHeads.com
          • YeOldeBuggy
            • 208
            Id say you should figure out why your gasket keeps leaking. You're not pressurizing your valve cover and oil pan, I hope?
            Thad.
            Need BMW parts?
            http://www.blunttech.com
            or face ultimate peril.
            • matias88e30
              • Dec 2009
              • 1110
              MR325: i used the cork gasket, where can i get the paper one?.. and i was thinking about silicone cause a guy tolde me that i could use some toyota silicone that its good, but not sure about it. Thanks!
              YEOLDEBUGGY:ill make sure everything its tight once im ready to get everything back together
              • brianpgriset
                • 138
                Permatex Aviation Form-a-Gasket plus good quality paper gasket... thats what I did no problems yet.
                • xwill112x
                  • Jan 2009
                  • 4236
                  Permatex grey silicon will work perfect, and cheapp. stuff is dynamite.
                  • xwill112x
                    • Jan 2009
                    • 4236
                    Not supposed to use gasket and permatex. Recently sat thru a permatex presentation and they specificly said not to.
                    • brianpgriset
                      • 138
                      TDS from permatex website specifically says solid gasket dressing under applications:
                      Beats me. I've used it for several years no problems.
                      • xwill112x
                        • Jan 2009
                        • 4236
                        They said that it could potentially not bond with some types of gasket material..so they recomended to use one or the other..not both. lol
                        • matias88e30
                          • Dec 2009
                          • 1110
                          I agree^, but thanks for the tip though!, where can i get that aviation silicone? or just go with the paper gasket?
                          • xwill112x
                            • Jan 2009
                            • 4236
                            Permatex's grey silicon is good stuff. prob the same or better.
                            • matias88e30
                              • Dec 2009
                              • 1110
                              Thanks for the help, ill see what can i do
