Wipers don't work
  • rwh11385
    lance_entities
    • 18403
    Wipers don't work
    searched and mentioned it to the parts guy at work. I don't think it's a transmission problem as I don't hear shit. the fuses look good.
    what else could be the cause of this problem?
  • sschin
    • 169
    Windsheild wipers?
    325i LSDed, 17x8.5 et15 BBS CH's, Bilstein Group N Suspension
    • rwh11385
      lance_entities
      • 18403
      i don't have any other ones.....
      • sschin
        • 169
        Hahaha just checking.
        Most likely the motor for the wipers are dead. Its a PITA to change, I heard.
        If the wipers go on and then cut out its the switch on the steering colum.
        I think thats what it is.
        Hope this helps alittle.
        • AdamF 88iS
          • 2051
          I see problems with the relay more often than the swtich. The large black relay all the way to the passenger's side of the fuse box controls all wiper functions. Check there first.
          Adam Fogg- '88 M3
          Common sense- It's the new 'gifted'
          • rwh11385
            lance_entities
            • 18403
            anyway to check the relay?
            at least on the fuel pump relay, there was no way to tell if it was bad except motronic telling me so......
            • Dave
              E30 RAT
              • 11675
              There's a guy named Todd here in Cincy who has a wiper motor assembly on eBay right now. I have bought a few things from him - he is trustworthy.
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • rwh11385
                lance_entities
                • 18403
                I'll go to the dealership today and hopefully pick up a relay just in case and try it out.
                and maybe check out that ebay.
                • rwh11385
                  lance_entities
                  • 18403
                  realoem says $60 for the relay. fuck.
                  i just remembered my 90 wipers work. i'm going to test it on the e with my relay from the 325i first. 8)
                    • 37832
                    I was about to suggest that, do the switcharoooo
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • rwh11385
                      lance_entities
                      • 18403
                      no dice.
                      fuses fine
                      relay fine
                      no sound of motor
                      • Dave
                        E30 RAT
                        • 11675
                        Faulty switch maybe?
                        Current Cars
                        2014 M235i
                        2009 R56 Cooper S
                        1998 M3
                        1997 M3
                        • rwh11385
                          lance_entities
                          • 18403
                          possibly. ?
                          hmmm.
                          how to test?
                          jump it somehow?
                          • nickmp0wer
                            • 1427
                            well i would think you could just take out the relay and use a wire to connect the + and - things, not the ones that drive the switch inside the relay, but the ones that the real power flows through. maybe have a fuse on that wire just incase
                            • KillerCalypso
                              • Jan 2004
                              • 459
                              My wipers go on and then cut out only on the first and slowest setting like you describe. Do you have experience with it being the stalk on the colum or is it more comonly the relay?
