The swtich provides ground to the relay. You can check for ground continutiy at the fues box while somebody fiddles around with the swtich. The pin numbers to do this should be in the bentley. Either that or you can try to directly power the motor and see if it moves.
Wipers don't work
Originally posted by KillerCalypsoOriginally posted by sschinHahaha just checking.
Most likely the motor for the wipers are dead. Its a PITA to change, I heard.
If the wipers go on and then cut out its the switch on the steering colum.
I think thats what it is.
Hope this helps alittle.
325i LSDed, 17x8.5 et15 BBS CH's, Bilstein Group N Suspension
Originally posted by AdamF 88iSThe swtich provides ground to the relay. You can check for ground continutiy at the fues box while somebody fiddles around with the swtich. The pin numbers to do this should be in the bentley. Either that or you can try to directly power the motor and see if it moves.
still, garrrrg. no driving in the rain yet.
http://www.bmwe30.net/cgi-bin/datacg...amp;Section=02My wipers go on and then cut out only on the first and slowest settingJohn
88 ///M3 Cinnabar
84 318i Black
