Help! Orgasm at 35mph.
    So now I got your attention. Please help me solve my problem
    My 325is starts to vibrate at 35mph. What could cause that?
    89 E30 S52
    Transaction Feedback.
    Control arm bushings, possibly strut mounts, tire horribly out of balance... what have you replaced and what is old? Does the steering wheel shake or just the car?
    Also this should be moved to the appropriate section.
    paint sucks
      The whole car vibrates. I don't know which section to put this inquiry. I replaced the wheels and tires. But I know it's not from that since the steering wheel doesn't shake.
      PS. How can this inquiry be moved?
      89 E30 S52
        Mods will move it when they come upon it. For future reference, this section is for documenting builds, not asking questions.
        It sounds like you need some bushings replaced and possibly an alignment. Wheels/tires are not necessarily ruled out if the steering wheel doesn't shake, if you've got a badly balanced tire in the rear you won't notice steering wheel wobble. How new are your struts/shocks and mounts? Basically there is play in your suspension somewhere, you need to figure out where that is and eliminate it.
        paint sucks
          Does it go away as you accelerate past 45ish? Check your driveshaft.
            x2
            how violent is the shaking?
            does it feel central or rearward?
            does the front end try to sway left or right when turning?
            what has and has not been replaced(to your knowledge) since you purchased it?
            have the wheel bearings ever been replaced?
            There are MANY different possibilities of the shaking and the best way to find out is to crawl under there and check all bushings, driveshaft, wheel bearings, and the rear half shafts. Not very specific answer but you're not really giving us much information to go off of...
            Originally posted by Ryan...
            It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
              @Wh33lhop, Well it is my project car that I am asking about. I just got this 2 weeks ago and I have not really taken it out into the streets yet until the other day. When I bought it, I had it towed due to a massive oil leak that I needed to fix. So I didn't get to test drive it at all.
              @drewhall, no it doesn't. At least not that I know of because I'm afraid to drive it faster than 35-45mph because the whole car is shaking so bad.
              What could possibly be causing the vibration?
              Wheel bearings?
              Driveshaft?
              Broken guibo?
              U joint?
              I doubt it's the shocks (billies) since our streets are pretty flat with asphalt. The wheels came from my old E30 which had low mileage so I doubt its that.
              It feels like it comes from the back. Is it possible to lift the rear end and run the car on drive? Should I be looking out for wiggle in the wheels? What should I be looking out for when I do that?
              89 E30 S52
                nothing has been changed since I don't know what's wrong with it still. I concentrated on the engine first and now i can pay attention to other things.
                89 E30 S52
                  NO!! Page 4 of the Bentley manual says never drive the car supported by jacks. Not because it might fall, though it might, but the rear half shafts can't take the angle.
                  x3 on the shaft.
                  Get under the car and start wiggling things. the drive shaft, suspension parts, anything with a bolt or bushing.
                  Been with me for 16 years...
                  Wish i had more time to play with her
                    Funny, sounds like my car. I'm pretty sure mine is a bad u-joint and or CSB (as it feels much faster than wheels with flat spots at a similar speed), and I'm in the process of pulling it apart to find out.
                    Ich gehöre nicht zur Baader-Meinhof Gruppe
                    Originally posted by Top Gear
                    Just imagine waking up and remembering you're Mexican.
                    Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
                      15 to 20 mph is usually center bearing, ds cv or diff bearing
                      25 to 40 mph grinds are usually wheel bearings
                      50 to 70 grinds/shudders are more likely suspsension related
                      A crapped out flex disc can give weird vibes at any speed
                        Yeah, if it's a quick wiggle (4x the frequency of the wheels) then it's driveshaft related, if it's a slower shake then it's likely your wheels/tires.
                        Get under the car. Inspect everthing--the driveshaft, guibo, CSB, etc. Start yanking on suspension components. Whatever gives should be replaced.
                        paint sucks
                          x3 on the shaft.
                          Well in that case you could put jackstands under the arms, but there are better ways to find vibration than sticking your face to a driveshaft...
                            x3 on the shaft.
                            What if I put all 4 sides up on jack stands and put the car in drive? Would that work?
                            89 E30 S52
                              Were you not reading what people were writing? The angle of droop of the trailing arms when the car is in the air is too steep an angle for the halfshafts. Putting the car up on all four corners won't change that at all.....
                              Max
