M52 vs M50 exhaust manifolds
  • permit
    • Mar 2005
    • 3363
    Bryson and I are wondering if both are the same, so that the M52 one (more flow) will bolt right up to my exhaust that was fitted to the M50 manifold.
  • nickmp0wer
    • 1427
    well if they were both the same i dont think one would have more flow
    • Jordan
      • 12913
      The OBDI cars have cast iron lumsp
      OBDII have nice SS tubular manifolds. Basicly shorty headers.
      OBDII manifolds bolt up to OBDI motors fine.
      https://mtechniqueabs.com/
      • permit
        • Mar 2005
        • 3363
        But are M52 manifold dimensions the same as M50 ones...I need to know if my exhaust thats fitted to the M50 will fit perfectly when I put the M52 in place (with M52 manifolds) without having to adjust/customize my exhaust.
        Jordan, I'm sure you answered my question somehow, but I'm slow and can't figure it out. You say the M52 ones are shorty style, but the M50 ones aren't?
        • e30Matt
          • 5077
          AFAIK the dimensions are the same. There's several E36s around here and a couple M50 swapped cars running around here with them on.
          • Ryan Stewart
            I Love Miatas
            • 8978
            same
            Im now E30less.
            • Low Level E30
              • 1646
              Old thread...
              Do the S52 headers PERFORM any different to the cast M50 headers?
              • permit
                • Mar 2005
                • 3363
                I never added to this, but OBD-II and OBD-I manifolds are not completely identical. One of the downpipes on OBD-II ones (forget if it's the front or rear manifold) nearly kisses the subframe. With OBD-I, there is much more room for an exhaust shop to work with.
                • Low Level E30
                  • 1646
                  You know you can run a complete E36 OBDII exhaust system from motor to valence, right?
                  That means the OBDII manifolds, center pipe w/ cats, and catback --- like it made to fit an E30.
