What is the best glue?
  • BAVARIAN IRON
    • 979
    What is the best glue for heavier plastic like plastic bumpers?
    Thx
  • Simon S
    • Oct 2004
    • 3758
    I reach for a two-part epoxy for such jobs. Available at auto parts stores. Comes in a little two-part plunger/dispenser.
    Clean it. Scuff it. [plastic] Weld it.
    -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
    • AndrewBird
      The Mad Scientist
      • 11898
      I like this stuff for plastic:
      It seems to almost melt the plastic you are bonding in order to get a good bond.
      • AT-JeffT
        • 145
        Keep in mind there are at least 3 different flexibilities of the stuff. Flexible, semi-flexible and non-flexible. Make sure you get the correct one for the application.
        chamfer the crack (assuming its a crack) before applying the epoxy.
        • BrettsE30
          • Feb 2011
          • 306
          I have this crazy stuff that is 2 parts. Its thick black or thin clear then you spray activator and it fizzles and pops then its instantly dry.
          I need your obd1 parts! Harness intake ecu etc.
          E30 Your Daily Money Pit
