Installing Blisten Shocks and H&R springs
    Originally posted by Alecs MacDonald
    Go ahead and remove the rear calipers and try rotating the rotors. If their stuck, remove the set screw and give them few wacks with a heavy hammer untill they come off. Put them back on and try rotating again. I suspect that its just your rear pads though. Remove the pads and use a clamp to push the piston back untill you can get the calper on the rotor freely. Then crank it up and try again.
    thank you, I'll head over to the grandparents now and try that out
    Thanks
    Jon
      Ok here is an update.
      I took off the caliper. It looks like the piston is out and pushing on the brake pad, is this normal? I thought this might be the only problem but when I tried to move the rotor without the caliper on it still woudn't budge! Do I need to take the rotor off and check something or is this an emergency brake problem now?
      Please help!!
        Please help!!
        THe piston should be out - yes. Not to suggest you are stupid, but do you have the parking brake off and the car in neutral while it is jacked up? Make sure it is off.
        If the rotors still aren't turning, then the parking brake pads are seizing for some reason.
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
          Please help!!
          Am I stuiped? No, but I sure as hell am new at working on cars!
          the car is in neutral and the parking brake is off. The parking brake pads deffinetly have to be siezed. They told me what to do on E30tech so I'll try that out.
          I'll have to adjest the ebrake while the rotor is still on, or something like that, or else the rotor wont come off? Corect?
          Thanks for your help so far everyone!
          Jon
            Some times you can't get them adjusted enough. on my 85 318i I had to end up prying the rotor off and replacing a bunch of stuff.
            85 325e 2.7 ITB'd stroker
              shit, hope that isnt the case.
              I just got that allen key bolt off. When I stick a screwdrive throught to rotate the star wheel, should I be turning left or right? Dosn't say in the book.
              Thanks
                Pry up your ebrake boot and loosen the two nuts on the cables untill there is no tenscion on them. Then with the rotor set screw removed beat on the rotor untill it comes off, this should "unseize" your seized ebrake shoes. Reinstall everything and hope for the best. BTW, from what I remember if you remove one thing from the ebrakes themselves, be it just a spring or clip, the whole assymbly will come apart and it is a royal PITA to get back together.
                '88 325ic
                  Ok I loosend the ebrake cables and then started waking the shit out of the rotor.
                  The rotor/hub (there connected, or are they just rusted together?) are very loose and can wiggle around alot now. I hear lots of screaching when I'm pulling, something is still holding it together. Should I be afraid to pull harder?
                  Thanks
                  Jon
                    Rotor and hub are seperate, just rusted badly, its normal. If I were you I would do whatever it takes to get the rotor off, I am not sure theres much you can do untill then.
                    '88 325ic
                      BFH may be your friend at this point
                      Current Cars
                      2014 M235i
                      2009 R56 Cooper S
                      1998 M3
                      1997 M3
                        BFH? Anyways I called it quites and came home for the night. The only thing holdig it on is that spring. I'll start fresh tomorrow and try again!
                          BFH - Big Friendly Hammer
                          Current Cars
                          2014 M235i
                          2009 R56 Cooper S
                          1998 M3
                          1997 M3
                            AKA: Big fucking hammer
                              So I should be ok beating he hell out of it even if its more than rust holding it on?
                                The BFH did the trick. Rotor came off. Now time to find out why the hell everything is locked up!
                                I tried putting the rotor back on to see if it would spin and it still lock so I knocked it off again.
                                The ebrake pads ( i guess you could say that is what is it, there are 2 U shaped pieces of metal) looked fucked. On the one side its bent outwards a great deal. The other side looks fine. I tried bending it back but no luck.
                                Do I need to replace these pads? Should I try doing the same thing on the drivers side just for safe measure?
                                Thanks
                                Jon
