Fan Clutch
  • PeaveyBassist
    • Sep 2004
    • 3511
    Fan Clutch
    I just got a new fan clutch. Has anyone ever taken off the fan without removing anything first to get to it? I'm just curious mostly. I've taken the fan off before when we changed the timing belt, but when I did that I had all the radiator hoses and the radiator out of the car. Is there any way to get the fan off easily? If not, what did you remove to take your's off?
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
  • Dave
    E30 RAT
    • 11675
    Re: Fan Clutch
    Will
    I took out the radiator when I did it. It only adds a few minutes to the job - the longest part is draining the coolant.
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • rs4pro3
      • 5808
      Undo the fan then pull the shroud and fan out, nothing else needs removed.
      85 325e 2.7 ITB'd stroker
      • aaron_silva
        • 1785
        Why would you remove the radiator just to replace the fan clutch?
        On the M42 I was able to remove the shroud first and the got the fan out with channel locks and a screw driver.
        Aaron
        • hamann318is
          • 3382
          Aaron
          The shroud is a pain in the ass to remove with the fan on. I like to remove the fan and shroud at the same time.
          The BMW 318 is back. With a vengeance.
          • PeaveyBassist
            • Sep 2004
            • 3511
            The m42 has a lot more room up there than the m20 does I believe. Sorry, I shoulda been more specific. I have a '91 325i. As for the fan shroud... is it just held on by expanding rivets? I dont wanna break all of em when I pull the shroud off. Any tips on getting just the shroud off first?
            Will
            DaveCN = Old Man
            • AdironRider
              • Dec 2004
              • 3491
              When I performed my timing belt replacement this weekend I noticed my shroud was held on by zipties. I wouldnt worry about breakin the little things, cause the zip ties work fine
              Back to my roots
              • hamann318is
                • 3382
                Those rivets are a pain in the ass to get back on. I used zip ties as well.
                  • 34844
                  you're kidding right? I put them on with my fingers. takes like 2 seconds.
                  • hamann318is
                    • 3382
                    Mine were impossible. I must have FUBARed them when I had them out of the car.
                    • PeaveyBassist
                      • Sep 2004
                      • 3511
                      So with the fan shroud off, I should be able to stick a screwdriver down there to hold the fan still while I loosen it from the water pump? I wont worry about the rivets, if they break I'll just use zip ties ;) Thanks guys.
                      Will
                      DaveCN = Old Man
                        • 34844
                        Will
                        it's easier to smack your 32mm wrench once or twice with a hammer. works every time.
                        • PeaveyBassist
                          • Sep 2004
                          • 3511
                          Smacking mine with a hammer didnt work. I used a long flathead screwdriver parallel with the ground (from the p/s for removal, d/s for reinstall) to keep the bolts from turning. Then used my 32mm wrench with a pipe on the end to loosen. Same to tighten back with new clutch. Took about an hour today. Beginning was figuring out exactly what to do, I cleaned up the fan in the middle for a couple minutes too. Could easily be done in about 30-40 minutes for a novice mechanic.
                          Will
                          DaveCN = Old Man
                          • Brew
                            • 3060
                            32mm wrench with a pipe on the end to loosen... Same to tighten back with new clutch.
                            Will
                            What'd you do that for? You're just making it harder on yourself or whoever works on it next.
                            It really doesn't need to be torqued even. The rotation of the engine/waterpump will tighten it plenty.
                            '91 318is
                            • PeaveyBassist
                              • Sep 2004
                              • 3511
                              I'm sure I will be working on it next ;) And I didnt do it till my arms hurt. Just enough to make sure it was nice and tight. I almost never torque anything. I just get it as tight as I can get it.
                              Will
                              DaveCN = Old Man
