Water temp gauge not working!!
  • tbone714
    • 115
    So I recently bought a 91 318is, and the temp gauge is not working at all. The two Si battery lights are on, so I know they need to be replaced, but all my othehr gauges work just fine. Is it most likely that the battery is the problem for the temp g not working, or is it a problem somewhere else along the line.
    Unknown if this is related, but when I turn my key to the "on" position (not ignition) my auxilary fan comes on at full power. Is this normal for the M42, or is the temp gauge problem causing the aux fan to defect.
    Im new to beemers, so laymens terms would be appreciated with your guys' responses, but I am a Certitied mechanic and have been working on subaru's for the last 3 years, so any atempt to help or diagnose will be much appreciated and most likely "understood"
    Code:
    [I]Originally Posted by[/I]: [B][SIZE="2"][B][FONT="Arial Black"]accident[/FONT][/B][/SIZE][/B]
    [I][I]Turn the tapatalk signature off[/I][/I].
  • bmwm42
    • 6300
    Basics: tighten nut behind water temp gauge. Check water temp sensor and wiring.
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
    • N2MYE30
      • Oct 2007
      • 5536
      A good whack on the dash and mine comes alive...not kidding.
      COTM
      • tbone714
        • 115
        The nut was already tight.
        Code:
        • tbone714
          • 115
          Which temp sensor are you talking about?
          Code:
          • tbone714
            • 115
            Still No bueno with this. I guess I'm having two problems now and i'm thinking the second is because of the first..Now I noticed my Aux fan isnt coming on except for when I turn AC on. I've already jumped the high and low speeds, and both work fine (and all fuses and relays are good) but when plugged into the radiator the fan doesn't come on at all. So I'll ask one more time, before I give up and take it to a shop. Is the water temp sensor, the brown sensor nearest the back of the firewall wall, or the blue sensor closer to the front? Anybody's help is much appreciated.
            (Is it a possibility the t-stat is bad too?)
            Code:
            • bmwm42
              • 6300
              Brown is sending unit for the dash blue temp sending unit is for the dme
              • bmwm42
                • 6300
                You can tell if the tstat is good or bad by doing a couple checks. Do you have heat, does the return hose get hot after a drive or does it stay cool?
                • tbone714
                  • 115
                  ^^^Thanks for the help, I will check to see if it gets hot tonight when I get home.
                  Code:
                  • Balkanac
                    • Apr 2011
                    • 50
                    im having a very imilar issue, the aux fan will not go on full speed ever, not even in 40C with the aircon on. i took the plug off the rad and connected the points and it does work at both speeds. I checked all fuses and relays but still nothing. My thermostat is about a year old, and the fan clutch was replaced at the same time. Could this be the switch on the rad?
                    1991 BMW 318is Brilliantrot
                    1998 Jeep Cherokee TD Black
                    • tbone714
                      • 115
                      Wish I could tell you as i am wondering the same thing
                      Code:
                        If the fan works at both speeds when you jumber the contacts at the temp switch connector, either the radiator never gets hot enough to trip the high limit switch (99C), or the switch is bad.
                        • bmwm42
                          • 6300
                          replace that damn switch lol shouldnt be more than 30 bucks for it
                          • be34st
                            • 1277
                            OMG THIS!
                            +1 this is the same thing I do when mine goes on the fritz.
                            07 Designio E63 AMG / 1984 318i (M20Swapped)
                            • Giormelo
                              • Feb 2011
                              • 23
                              I don't mean to hijack your thread but since you guys are talking about gauges on the cluster, is there any way to test all the gauges and lights on the cluster?
                              I know and I've done it on my dads x3 that you hold s/r(dont know what its really called) and turn the key to position 1 or 2 etc etc.
                              Is there anyway to do the same on an e30 cluster?
