A/C Makes My Engine Wanna Stall.
  • Vtec?lol
    • Dec 2009
    • 3278
    Hey guis. So after doing a head swap and gasket change got the motor running great M42. But now when I cut on the A/C the engine wan'ts to stall.
    I tried effing with the idle screw but that just makes the idle gay when the a/c is off. This is odd as every other car I've had it's the exact opposite. The engine r3vs up when you cut the a/c on..... my car doesn't do that, it boggs down
    Help please?
    If the idle speed increases when the A/C is engaged, I'd suspect intake leaks and/or a cam timing error.
    • wodcutr
      • Apr 2009
      • 2193
      The idle speed is supposed to increase when you push the blue AC button to compensate for the extra load!
      The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
      • Vtec?lol
        • Dec 2009
        • 3278
        no, I'm sayings it's the opposite, my car revs up to 1.8k when the ac is off! it bogs down to 300-500 when the ac is on and wants to die
        • Vtec?lol
          • Dec 2009
          • 3278
          please?
            • 34847
            sounds like your idle system is not functioning and/or you have severe vac leaks.
            also, Motronic 1.3 cars and later do not have an idle screw. If you've adjusted your throttle stop, put it back the way it was. The idle control will not work and it will cause problems like you've described.
            • dandrewg
              • Jun 2008
              • 76
              no, I'm sayings it's the opposite, my car revs up to 18k when the ac is off! it bogs down to 300-500 when the ac is on and wants to die
              I want a motor that revs to 18k. How long did your F1 swap take?
              • wodcutr
                • Apr 2009
                • 2193
                I would say you need to test the ICV to see if it is working properly. Get a bentley manual!
                • Vtec?lol
                  • Dec 2009
                  • 3278
                  I Have a bentley manual and I've already checked vac leaks and the idle valve has been checked cleaned and replaced. same issue. Trust, I went through some things before posting.
                  • Car Addict
                    • Mar 2007
                    • 1100
                    the m42 does not have an idle screw!
                    what did you adjust in the first post?
