speedo was working. but then stopped.
  • Kershaw
    • 11822
    when i bought this car (11/88 ) 325ix, the cluster would work sporadically. i assumed a bad si board. either the tach would work or the speedo. gas kind of. temp always. so i replaced the cluster, but kept the speedo gauge for the odometer. motometer to motometer btw.
    when i first started up the car, all the gauges worked except the speedo. a friend said drive it around and let the si battery charge up. so i left it for the next day. surprise, next day everything works. speedo works until yesterday. also, gas is intermittent, if you tap it, it'll work again. but if you hit a bump it'll zoom to full. zoom. the lights on that half of the cluster also go out, but tapping the top will turn them on. nothing i do makes the speedo work though.
    im at a loss.
    to further my problems, the switched power for the stereo is not switching on. which it was, a few days ago.
    AWD > RWD
  • nrubenstein
    • 3148
    What does the fun (economy) meter do when the speedo stops working? If it reads normally, then you have a speedo issue. If it basically goes from one side to the other, then you have no speed signal.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Kershaw
      • 11822
      yeah. it goes from one side to the other. odometer also stopped working.
      plug looks ok at the diff.
      AWD > RWD
      • bsop
        • Jul 2008
        • 116
        I had a similar issue, sporadic speedo etc. Fixed it by replacing the gear in the cluster that the speedo relies on.
        It was basically stripped and simply would not engage. Apparently its a pretty common problem with our clusters. I found a write-up for it either on here or bimmerforums, if i can find it again I'll post the link.
