Rear wheell hub nut HELP
    Ok Guys,
    Forget using a socket to get the rear wheel hub nut off.. Any ideas, split it with a cold chisel, torch it off, let me know what to do.
    Thanks
    Barry
    Did you tear up the nut already or it just wont break loose? Soak it with pb blaster, maybe heat it up, always break it loose with car on the ground + e-brake. Usually tapping on the tool with a hammer will do a better job of getting it broken free than just pushing on the tool.
      Impact
      Originally posted by Gruelius
        The nut is rounded I never had the nuts off since I owned the car I used a whole can of blaster. Did not heat it yet.
          The nut is rounded now?
          Buy a new trailing arm and half shaft.
            I'm thinking heat and a cold chisel will work
              If its rounded... grind a slot in it with a dremel and hit it with an air hammer with a chisel attachment to get it moving.
                If you are careful you can chisel it. Torch it then split it down the middle.
                DENY IGNORANCE!
                Schwarz 325-totaled
                brilliantrot 318i-daily
                Originally posted by mkcman17
                don't think your hamster wheels are fast now. you will still have to give up when trying to pass that V6 odyssey to make your offramp.
                  Exactly thats it I'll let u know how it worked.
                  Thanks
                  Barry
                    mine aswell find another trailing arm at a wrecker.... your going to mangle the threads on the shaft anyways....and possibly kill the bearing, im assuming you took the locking ring out before you started trying to remove the nut?
                    Full Build Thread Here
                      The whole point of the exercise is to change the bearing, there is plenty of room to notch the nut and bang it loose maybe with a little heat, I have the patience.
