Window switches - how to do you repair 'em?
  • mach schnell
    • Apr 2008
    • 1059
    I have two window switches that don't work at all, and one that works only in the down direction.
    I know the windows themselves operate, because I took the one good switch and tried it in all four positions - all work fine.
    So I need to repair the other three.
    How do I do that? Do I have to take them apart somehow?
  • Sagaris
    • Sep 2009
    • 2243
    I have 4 or 5 of them that you could have for cheap in case you just want to pop some working ones in
    • evilnickwong
      • Aug 2007
      • 302
      You can pry the switches open, look around the sides of each switch, there are tabs that hold the sides in place. Once you pull it apart, you can check to see if the contacts are still in good condition and clean them down if not.
      • MrSlacker
        • 2494
        Stock switches are so cheap, I dont know why you would even bother
        My Seller/Buyer Feedback
        Performance Aftermarket Parts & Accessories
        • mach schnell
          • Apr 2008
          • 1059
          New ones? How much, and where?
          • mach schnell
            • Apr 2008
            • 1059
            Sounds good, thanks.
            • reelizmpro
              • 9552
              This. Clean and lube them up.
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
              • blackhawkimpact
                • 2415
                I'll sell you a set of 4 tested and working illuminated switches for $30 shipped
                • Ceeker
                  • Sep 2009
                  • 2821
                  ^^^ like he said; buy working used illuminated -not worth trying to fix.
