bbs rs redrilling questions
  • Sputnik
    • Jan 2010
    • 808
    Hey yall, I got a pretty nice set of rs 061's the only problem is that they are 5-lug, and since their will be to much offset with adapters the only option is to re-drill them and I wanted to know if that is possible on a 3-peice rim and also if it is going to depreciate the value if I do redrill them
    Thanks in advance! :D
  • Sputnik
    • Jan 2010
    • 808
    Actually, since the rs's have a offset of 20 would it still be possible to run adapters?...(I'm a really big wheel noob so sorry if I sound stupid)
    p.s. sorry for making this thread in the wrong section...
    • Kershaw
      • 11822
      you could run 20mm adapters. you'd just be running 0 offset.
      which is fine if you're hellaslammed and you want hellaflush. you'll need to roll your fenders and get camber plates.
      AWD > RWD
