clackity clack clack clack
    So when my engine idles in neutral my car makes a clackity clack clack sound, when I push in the clutch the sound slowly goes away and ceases, If I rev up the engine in neutral the sound goes faster too, what can this be?
    one of the bearings
    throw out or input shaft
      Is a part on the tranmission? how easy/hard is it to change?
        99% chance it's the bearing on the input shaft of the tranny.
        Just deal with it; you can't change the bearing without rebuilding the whole tranny.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
          Ahh shit, will it cause an imminent failure, or soon failure of the tranmission? What else could go wrong because of this? Or is it just noise to deal with?
            It won't cause anything. It'll run like that for the rest of it's normal life.
            Adam Fogg- '88 M3
              Re: clackity clack clack clack
              i have that same exact noise.
              if it's not a problem i'll get over it.
                Mine's done this for the last three years...
                Just push the clutch in before you turn it off! ;) No more problem!
                The noise is the clutch release lever rattling against the input shaft as the engine shudders to a stop. When you push in the clutch, the lever has pressure on it and doesn't shake. Not to worry! It's not broken...
