Engine starts fine but runs poorly
  • kylebes1
    • May 2004
    • 2804
    bet .02$ it is the timing. I have never had an m20 powered car
    sounds to me taht the timing is advanced too mucho. maybe the other way :roll:
    • kowalski
      • Jan 2005
      • 1791
      no problem, good luck with the fix.
      • formula driver
        • 2263
        Thanks alot guys. I will check all these things.
        • formula driver
          • 2263
          Anyone else have any ideas of things I could check before I pack my tools up and set out?
          • formula driver
            • 2263
            Could this have anything to do with the exhaust (cat)?
            • formula driver
              • 2263
              Well my car is still not starting. It wont run at all anymore. I replaced the coil and it didnt fix the problem. Im geting a week blue spark off both of the coils co could it be possible that I got a bad coil?
              • formula driver
                • 2263
                Guys I need help... baddddd. I replaced the coil and I was getting a strong spark off the coil but the car wouldnt start. I put a plug in the end of a wire and grounded it. No spark!!!!! Tested the coil again and it lost its spark??? Why would it do this? Could this have anything to do with my ECU?
                • Garageaholic
                  Freestyle Fabricator
                  • Dec 2005
                  • 5204
                  vacuum leak perhaps? even though it was almost a year ago..
                  Recent Rebranding!!
                  E30 SM62/S62
                  E30 M60 V8
                  E30 M30 Big 6!
                  Instagram.com/garageaholic
                  Youtube.com/garageaholic
