I just got my 325ix back from the shop.. They fixed a huge leak in the intake manifold gasket, and now since i've gotten it back a few things are going wrong... almost like the damn thing got used to running with a big ass hole in the gasket
First off, it doesn't start as quickly as it used to.. I used to turn the key, and it fired right up.. now it can take up to 4 seconds of holding the key..
Second, when i'm sitting idle (which is WAY too low, around 400rpms) when i step on the gas, the car bogs first, lowering RPMs, then revs up fine.. if I barely tap the gas, it bogs and kills...
So i've put new plugs in it, and wires.. Haven't checked the rotor and cap yet, but the car runs fine other than at idle..
I did the blink code test,, and got 3 blinks... I tried it again about a half hour later and got 2 blinks...
WTF? I thought it was supposed to give 4 different sets of blinks... Could all my problems be because of the ECM? maybe the AFM? I unplugged the TPS sensor, and it seems to help with the idle speed, until it sits a minute then it drops back down to the rough idle, and does the same exact things..
If anyone has had anything like this happen, or knows what the hell the blink code means, I'd REALLY appreciate it.. i'm tryin to sell this car, and i can't have it running like this...
BTW its an 88 325ix
Thanks ya'll
BTW its an 88 325ix
Thanks ya'll
