Electrical issue??
  • billybobjoseph
    • 213
    If you have a good ohm meter with back probes and long enough leads you can test it that way from engine compartment to under the dash with a friend. Again disconnect the battery first. If it's green with a brown tracer there's a ton of them under there.
    • Lrutts
      • 104
      Originally posted by jlevie
      That green wire sounds like it might be the "Hot in Run and Start" lead from the ignition switch.
      What does that mean? The only symptom that the car has since the short out is that 50% of the time when I start the car, it will idle soooo rough until i rev it up to about 3grand for 10 seconds or so, then its all good.
      Too small? Blood Sweat and Tears Build:
      http://www.r3vlimited.com/board/showthread.php?t=202389
      • billybobjoseph
        • 213
        Bomb ass wiring diagram at http://www.diakom.ru If you can tell me the tracer I can probably tell you which one it is or at least narrow it down for you.
        • billybobjoseph
          • 213
          Scratch that site, it's in Russian.
          • billybobjoseph
            • 213
            it's http://www.diakom.ru/CARS2/index.html select BMW from menu on left. Then select the first Russian phrase on the right.Then select third Russian phrase below that ( says Mitchell next to it). In drop down box select year, next drop down box select model, third drop down box select wiring diagrams.
            • Lrutts
              • 104
              All right will do, i will check it with an ohm meter
