manual to power sunroof swap
  • oldskool3
    • Mar 2005
    • 401
    I am looking to get rid of the e21 and pick up an e30 and I have found a super clean e30 for sale around my price range with only one thing bothering me it has a crank sunroof. So I was wondering if anyone has ever swap in a motor for the power sunroof and if it is possible? Thanks for any help you can give.
    Photoshop by O 16581 72452 5
  • nickmp0wer
    • 1427
    I have a crank and its not that bad, but i think if a car has a sunroof then it should be power. But on the other hand you can probably crank it just as fast if not faster then the time you have to hold the button
      • 34844
      power sunroof retrofits, you need the power sliding mechanism, motor, wiring, switches and the panel with a hole cut out for the switch.
      screw crank sunroofs/windows, I've had that before in a car older than everyone on R3v.
      • oldskool3
        • Mar 2005
        • 401
        I know I have a crank in the e21 right now and Im not really a fan. I dont mind it but would definetly prefer power. I dont understand everything else is power except the sunroof. Anyways thank for the help
        • 88ix
          • Jun 2004
          • 15
          i personally think the crank sunroof adds to the character of the car. i'm a little surprised i guess by your s/n that you may not agree, or see that it's kind of neat. :)
          • oldskool3
            • Mar 2005
            • 401
            I felt that about my e21 it added character and I was just happy to have a sunroof on such an old car but I would now like a little more luxury and that is why I am planning on picking up this e30. I have delt with the crank long enough now I would like some power. Especially since everything else is power. :)
            • zandi
              • Apr 2004
              • 602
              When I had my 91 e30, i had power sunroof, it was fucked up though, thing seems to break a lot because i had it fixxed and it broke again, then i was looking at the 89 e30 that im driving now and test driving it, and i saw something wierd on the roof, i asked the owner, what the fuck is that? Oh its a crank for the sunroof, isnt it sweet? And sweet it is, dude really, the crank is better than the power sunroof on e30s, trust me.
              • oldskool3
                • Mar 2005
                • 401
                I know what your saying I have had both power and now crank on the e21. I know it is not that bad but I thought if it was an easy swap to change it over to power i would. Thanks for the input
                • netcsk
                  • Apr 2004
                  • 1609
                  I've done it, it's not a bad install. You need the copper tubing, motor, relay, switch, and the head liner to swap out. I like it much better in my car now, plus I installed AutoLoc One-Touch windows things on everything (windows and sunroof) so I only have to hit the button once to open/close it. Worth it in my opinion.
                  To swap out, you remove that front headliner piece and remove the sunroof. It's fairly straight-forward from there.
                    • 34844
                    nonesense. don't blame your technical imcompetence on the power sunroof. mine has always worked flawlessly as have many others.
                    • DanGillan
                      • Mar 2004
                      • 4061
                      i did the swap, its kinda hard to get everything lined up perfectly becuase it comes from the factory rivited in there and you have to drill them out and if you bend any of the plates your pretty fucked. it took me the better part of 6 hours to do, but i was just doing it, no guidance, no write up. its definately do-able.
                      Dan
                      • kylebes1
                        • May 2004
                        • 2804
                        I had a crank sunroof on both e30s
                        I loved taking my GF out, she liked teh m50 kick (mostly because of the 3.73 LSD). But when I thought about opening the sunroof, well I didn't.
                        My next one will have a power roof. hopefully a Lexan one :D . That and I want to install the button down where the other window buttons are, along with the one-touch....
                        • Sean
                          • 5793
                          Nichole was in my car last night.
                          I opened the sunroof, and she started laughing at me.
                          Keep it in! 8)
                          - Sean Hayes
                          • kylebes1
                            • May 2004
                            • 2804
                            I would have elbowed her in the fucking face
                            not really, jsut would have been like, "Wha?"
                            • soliver
                              • Feb 2006
                              • 40
                              I just broke off the crank in my car, so I'm thinking about a power sunroof. :curse::curse::curse:(and laying off the roids)
                              If I'm interpreting this thread correctly you have to remove the entire sunroof assembly? Can't the motor be installed in place of the crank and use the existing sunroof? What's the story fellas?
