I've used a 16" fan rated at 1800 which was barely adaquate here in the South under race conditions. It made no difference whether it was mounted as a puller or pusher. I'm currently using a 16" SPAL puller rated at 2300CFM and it have proved to be more than adaquate even under the worst conditions. I didn't use and shrouds for any of these.
One word of advice, mounting the fan directly to the radiator core (the easiest) can result in the mounts eating a hole in the fin tubes. I'll leave it as an exercise for the reader as to how I know that. Okay, two words of advice. Use a thermo switch that trips a few degrees above the thermostat rating for automatic operation. With the standard 80C stat an 82-83C thermo switch works great. The aux fan thermo switch trips too high (low at 91C, high at 99C)
