Signal lights dont automatically stop after turning steering wheel
  • frickendom
    • 382
    Signal lights dont automatically stop after turning steering wheel.
    How do I fix this?
  • jaywood
    • Jul 2010
    • 4528
    How do I fix this?
    You need a new piece of plastic in there. I forgot what they're called though.
    Just get a whole new lever
    • evilnickwong
      • Aug 2007
      • 302
      I have the same problem for my left signal. So it's just a broken plastic tab or something on the lever itself?
      I assume access is just via removing the bottom and top steering column plastic covers right.
      • frickendom
        • 382
        Ergh. I dont quite understand. Can somebody explain it more detailed? Perhaps pictures might help...
        • bmwstephen
          • 2463
          If u guys r switching from an airbag vehicle, I'll need to pull off that white pin
          • e34john
            • Apr 2006
            • 3599
            Take your steering wheel off, you will see what we are talking about. Theres a tab on it that cancels the lever as it comes back, if that is still there, the part on the signal stalk is probably worn out.
            • Ian Bowers
              • Apr 2008
              • 1120
              The steering wheel has an assembly called a "Slip Ring" on it. The function of the part is to simply hit the cancel for the stalk when turning. It's not a super sturdy part, and can break. You have to remove the steering wheel to service the part. It's not replaceable on all steering wheels, but it is on Mtech 1/2 wheels.
              • frickendom
                • 382
                The slip ring is on the steering wheel? Do you think you can get a picture?
                • mr.vang
                  • 4371
                  yes its on the steering wheel. there should be two small screw on the back. if your horn doesn't work the PO must have taken out the slip ring. if you put a non-airbag wheel on a airbag car you will have to remove that slip ring because the slip ring will scrape on top.
                  • Ian Bowers
                    • Apr 2008
                    • 1120
                    Google image search came up with this:
                    It's similar, not exact. The idea is the same, though. It's the piece of plastic with an erection.
                    Uh... you're confusing shit now. You do not remove the slip ring on an airbag car if you switch to a non-airbag steering wheel. That's bullshit. You remove a white pin that is in the steering column. See this thread.
                    • frickendom
                      • 382
                      Thanks Ian! I will be checking this out tomorrow hopefully.
                      If that plastic erection is busted, I need a new steering wheel? (Hope so! So I can get Mtech, hehe)
                      • Ian Bowers
                        • Apr 2008
                        • 1120
                        It's replaceable on some wheels, but I don't know exactly which. You might get lucky and be able to buy a new one. If it is broken, brand new ones can be purchased for around $15.
                        • evilnickwong
                          • Aug 2007
                          • 302
                          That plastic tab is fine on my wheel, so I guess something on the lever is broken then?
                          • Kershaw
                            • 11822
                            the spring....
                            AWD > RWD
                            • jaywood
                              • Jul 2010
                              • 4528
                              Most likely it's not the spring or the plastic tab on the back of the wheel.
                              Take off your wheel and look on the inside. Flip the lever up and down and you should see a little plastic tab that pops in and out. That's what cancels the signal. When the plastic tab on the back of the wheel hits the plastic piece that pops out on the inside (the end of the lever) it cancels the signal. You probably need a new lever
