So I was about to embark upon replacing my slave cylinder on my clutch. I was super nervious because of all the horror stories. It seemed the hardest part was the bleeding. I have bled tons of motorcycle brakes and clutches... and I remembered a tool I used to have. I searched for it and sure enough it was at my moms just where I left it. This tool is basically a one way valve with tubes on both sides, when using this tool you.no longer have to have a buddy tightining the bleed valve. You just pump away. So using this tool the bleed took only about half hour. And that was me being very precise and carefully. Maybe someone else has used this tool bit I have never heard it mentioned on the forum. Anyways here is a link for the tool! Hope it works for you guys too.
http://www.rockymountainatvmc.com/pr...dFamilyId=9518
