Water pump bolt problem
  • b*saint
    • 3794
    Hey you know what you need? Try a left handed drill bit?
    Ma che cazzo state dicendo? :|
    • b*saint
      • 3794
      I dont know how you do it bro. I would've given up after the first day.
      • Julien
        • 7472
        don't try to drill the bolt extractor. use a hammer and a pick to shatter it.. seriously. g/l.
        Build Threads:
        • bmwcalvin
          • Jan 2010
          • 424
          Can't fit one in there not enough room. Unless I pull the whole front end off the car...
          Originally posted by IRON-E
          Skirtz are for zeh womenzzzz....
          • bmwcalvin
            • Jan 2010
            • 424
            The Cobalt drill bit didn't seem to make a difference and I ran out of battery again. Not sure what to do next?? I could pull the front end off so I have room...
            • blackhawkimpact
              • 2415
              Same thing happen to me only it was two bolts in the thermostat housing. One of the easy outs broke also in one of the bolts. Took it to a shop and they took both out for $80.
              • bmwcalvin
                • Jan 2010
                • 424
                Should I just push the car down the street to a shop and have them take it out then? Or just pull out the motor?
                • bmwcalvin
                  • Jan 2010
                  • 424
                  ^Seriously I'm going to call a couple shops that are close by in the morning and see what they would do if I pushed my car down to their shop..
                  • bmwcalvin
                    • Jan 2010
                    • 424
                    So the shop spent 2 hours trying to drill it out this morning and they couldn't get it and told me "Good Luck". So now my car is sitting in a machine shop waiting to see what happens tomorrow morning. Should be interesting, thankfully I was able to use a tow on AAA. I can't work without a car so this is really getting to me..
                    • b*saint
                      • 3794
                      Fuck bro. I literally feel bad for you. I know what this shit is like. In the future maybe use a torque wrench??
                      Just dont get discouraged. Live and learn. Next time you'll know not to do that again and you'll be a better mechanic.
                      • bmwcalvin
                        • Jan 2010
                        • 424
                        Yeah I have been kicking myself this whole time. I used a torque wrench and read ft instead of inches.. If they can't get it tomorrow, I'm gonna have to buy a new block. I can't afford one so it be interesting...
                        • bmwcalvin
                          • Jan 2010
                          • 424
                          Well I got the bolt situation taken care of... The guy welded a bolt to it and cracked it out in a 1/2 hour this morning. I rented a tow dolly and borrowed a truck and then had problems getting it on the dolly by myself. The guy pushed the car on with a fork lift and it slip off the piece of wood and just barely hit my cam sprocket.. So Now I get to go to a pick your part in the morning tomorrow, But I should have my car up and running by tomorrow night!
                          • b*saint
                            • 3794
                            Awesome dude! I forgot about that trick and its actually widely used.
                            • bmwcalvin
                              • Jan 2010
                              • 424
                              I got everything installed and now it sounds like there might be something wrong with the cam... Heard some valve knocking in the one all the way up front (#1?) I opened everything back up and found metal shavings in a couple of places as well.. Neeedless to say no Bimmerfest for me this weekend. Looks like I may be pulling my head off...Literally.
                              • bmwcalvin
                                • Jan 2010
                                • 424
                                Ended up being a tensioner pulley that was loose... All good now!!! Runs like a champ!
